no key and want to hook up a toggle switch
  • odl666
  • odl666's Avatar Topic Author
22 May 2006 17:17
#49237
I have just bought a kz 650 1978 and am in the process of getting her running. Unfortunatly i broke the key and want to get her running before i buy a new ignition. I was wonder what wires i need to hook up to my toggle switch to get power to everything. thanks
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
  • apeman
  • apeman's Avatar
Re: no key and want to hook up a toggle switch
22 May 2006 17:53
#49246
The ignition switch has a bunch of wires routed through it. You could start the bike just jumping the ignition and starter circuits, but then you would not have lights. You could also simply remove the ignition switch from the mount (go though the bottom, behind the headlight), and remove the lock mechanism, then turn the ignition switch with a screwdriver.
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
  • dutchz
  • dutchz's Avatar
22 May 2006 18:10
#49252
Apeman is right, you will not have lights without rewiring. There should be three wires to the ignition switch if I'm correct, don't have a 650 wiring diagram. I had a generic Autozone toggle switch on mine before I put the keyed ignition back on, I connected white (load) and brown (supply) to the toggle switch that should do the trick. Keep some fuses handy I'm no electrician :whistle:
1974 Kawasaki Z1
Stock front hub and rear axle.
  • odl666
22 May 2006 18:32
#49265
i am gonna try that right now. thanks
1979 gs750e
  • DanOz7Five0
  • DanOz7Five0's Avatar
22 May 2006 18:37
#49268
If I remember correctly, everything gets hooked together except either one of the white wires. Then the white wire will be on either side of the toggle switch.
I couldnt see clearly enough while browsing for the pic but heres what you should (might) have
Post edited by: DanOz7Five0, at: 2006/05/22 21:40
  • dutchz
  • dutchz's Avatar
22 May 2006 18:38
#49270
I cut some short strands of wire and put bullet connectors on them that way it's easy to switch back.
1974 Kawasaki Z1
  • DanOz7Five0
22 May 2006 18:45
#49274
Here are 2 links to a wiring diagram for your bike also
img.photobucket.com/albums/v431/danyeek/...%20bikes/wiring1.jpg
img.photobucket.com/albums/v431/danyeek/...%20bikes/wiring2.jpg
You can print them out and tape them side by side for an easy to read diagram
Post edited by: DanOz7Five0, at: 2006/05/22 21:46
