Brake light always on
- dfinnegan71
08 Dec 2011 21:03
Hi kz riders. Noob with brake light question. The title says it all. I changed out the stock rear brake light with an LED light, and changed my flasher relay to keep up with the new LED turnsignalas. The signal work as they should but the new LED tail light is always in the "on" or "braking" mode. I have tried the three wires in every configuration possible. Any ideas?
1981 GPZ 550 mild custom
- gengomerpyle
Re: Brake light always on
08 Dec 2011 21:09
sounds like its wired backwards
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
08 Dec 2011 21:10
Including information about bike year and model may elicit better responses.
And it's easy to put the information in your signature where it will automatically appear in posted messages. When done, the signature information appears in all posts, past and future.
And may be changed as often as desired.
Would check adjustment of the rear brake switch.
Attachment addsig.jpg not found
- dfinnegan71
08 Dec 2011 22:05 - 08 Dec 2011 23:03
thanks! So that's on a 1981 GPZ 550. Patton, i tried switching up the wires that didn't change anything, other than no light at all. I am stumped.
Last edit: 08 Dec 2011 23:03 by dfinnegan71.
- MFolks
09 Dec 2011 01:19
Here's the wire colors for the brake and running light(Tail light):
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
BLACK with YELLOW stripe, the ground circuit.
If the brake light is constanly on, see if the right handle bar brake switch is damaged, or the rear brake switch is sticking(both can energize the rear bake circuit).
- dfinnegan71
12 Dec 2011 18:01
thanks MFolks. both brake light swiches move like they should, meaning neither one is stuck. The wires from the light are Black Red and Yellow. I assume I put color to color?
- andy9802gt
- If it tastes that good, eat it yourself.
12 Dec 2011 18:49dfinnegan71 wrote: thanks MFolks. both brake light swiches move like they should, meaning neither one is stuck. The wires from the light are Black Red and Yellow. I assume I put color to color?
You know what they say about assumption? Very rarely are the colors on an aftermarket light the same as a stock one. Hell, the zx12 taillight I put on my bike had different color wires, so even kawi to kawi are different. Time to unhook the taillight and start one wire at a time trying to figure out which wire runs which part of the new lamp.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- ramtough_63
12 Dec 2011 20:42
Most after market (chinese tail lights use whatever color they want for wiring 1 I looked up said Brake/red Tail/red lisence plate/white there wasnt a redwire on the pic shown it was yellow. another said red/brake green/running black/ground the green was blue
I would start with red for brake yellow running and black ground assuming you dont have a license plate light. the running and brake on the ones I have hooked up will go either way with no difference.
Attachment taillight1.jpg not found
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- ramtough_63
12 Dec 2011 21:01
use a test light to test the red wire on motorcycle it should be light up with the ignition switch on. then test the BLUE,(sometimes with a Red stripe) wire it shuold not light up until the brake lever(s) are applied.
connect the test light to a good ground Ie: battery negitive post to do your testing then use the BLACK with YELLOW stripe, and check everything again.
Sometimes people get the brake wire and ground backwards (neither of which would cause your problem)
I have heard of bad circuit boards in the use of universal tail/brake lights but after hooking several up I have not run acrossed this problem.
I am sure hooking one up backwards could mess up the inexpensive circuit boards used. I have been lucky. It has taken more than one try after wiring one up and putting it back together but I blame it on my ADD and not getting a good solder or pulling connections apart during reassembly
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- dfinnegan71
12 Dec 2011 22:45
Thanks guys. I will give er a try again tomorrow and let ya know.
