Led conversion Pilot light problem
  • moke
  • moke's Avatar Topic Author
  • Been there, done that, still doing it!
08 Dec 2011 02:24
#492138
Im in the process of lowering power consumption and ive found a low load flasher from a previous project. Now when i attempt to use the flasher I have all four blinkers turn on instead of the two. I left the previous incandesent bulb in the cluster which barely lights and is transfering power to the other side. What can I do to correct this without using a resistor (defeats the purpose) or removing the bulb
It's not what you ride it's that you ride!
1980 Kawasaki KZ250 LTD (current project)
1978 Honda CB400
1987 Honda Elite 50 (speed project)
  • Motor Head
  • Motor Head's Avatar
Re: Led conversion Pilot light problem
08 Dec 2011 10:00 - 08 Dec 2011 10:01
#492167
So to test your back feeding theory, have you removed the indicator bulb, and then each turn signal side/ circuit works correctly?
Last edit: 08 Dec 2011 10:01 by Motor Head.
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
08 Dec 2011 16:25
#492208
Are you sure you have the right flasher? You'll need a two prong no load flasher, not just any no load flasher.
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • moke
08 Dec 2011 19:15
#492233
both sides work correctly no doubt they work when pilot is removed, otherwise all 4 blink when pilot is in would i have to wire a relay into the circuit? I understand LEDs use such low current and that causes the all four flash and both sides meet at the pilot would it be easier for me to machine out a guage plate and make my own with two leds for both sides?
1978 Honda CB400
  • BikeDude2002
  • BikeDude2002's Avatar
  • Today is a good day to ride...
11 Dec 2011 00:44
#492604
The use of your 'low load' flasher may or may not be low enough to cause the flasher to function properly. The flasher must be LED compatible, meaning it must be able to operate at very low current draws AND be non-load sensitive meaning the lamps will flash at the same rate regardless of the load (number of lamps, up to the maximum current draw). I suspect your flasher may be of the load sensitive type. These flashers are made to operate normally (normal flash rate) under certain conditions, but if the current draw is outside of designed range, the flasher speeds up (typically twice as fast) to notify you that a lamp is burned out. Assuming you don't have any other electrical issues, this is likely the cause. Check out the flasher at www.cwswiring.com or one of similar specifications.
78 KZ650 SR
90 Yamaha Radian
