- Thank you received: 1
Jumpy Tach readings - Cable play
- DivideOverflow
My Tach needle jumps up and down when above 3krpms or so. It doesn't sound or feel like the motor is jumping around, and it is riding great. I can wiggle the tach cable as it goes into the engine from left to right, but the connector is definitely screwed on tight. Could it be missing some washer, or some other part missing that allows it to have free play?
The higher the rpms, the more it jumps up and down.
Thanks!
1980 KZ750E1
North Carolina Crew
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Pull the ends off and check/lube cable properly.
Most likely it is the internals in the tach are getting weak.
You can hook a dremel up to the tach and try different rpms to see if it is the tach or the connection.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- MFolks
- Thank you received: 540
While it's apart, clean and inspect the twisted inner steel cable for damage, and lubricate with a light grease & re-assemble. If broken strands are found, only a new tach cable will repair this problem.
- Topper
- Thank you received: 133
Engine seems to be running pretty good. Is there anything other than the cable that could cause this? I mean the tachometer itself is 30+ years old.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
- bearshawk
either way i would LOVE to block off the tach hole in the front of my engine, it would stay alot cleaner that way
1978 kz650 sr- long time project/first bike mostly gone
1979 kz659 sr- new acquisition NEXT project GONE
Both 650s combined to make one great bike! with a new powerplant
it is a 79 frame, 78 front end, both 78 wheels and brakes, 78 body work and a 80' 750-4 motor with gpz 750 cams and a kerker and...
- Thank you received: 2098
bearshawk wrote: same issue... i went cafe and i am seriously coinsidering just running a GPS and getting rid of the entire gauge setup, its more annoying than anything, or i have seen a bunch of guys go with the acewell setup, they are electric i believe?
Offered by Z1E --
Click > www.z1enterprises.com/Tachometer-Drive-B...-Z1-KZ1000-2647.aspx
- bearshawk
- TeK9iNe
The acewell stuff and most newer tachs use a probe wire that goes to the ignition coils to determine engine speed.
Hmm... to bad theyre so expensive. really shouldnt be.
Veypor makes a decent unit.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- wakeboardr42393
It makes me feel better that other people are having the same issue that might just be old meters. I am now more confident that I'm not overlooking something stupid
1981 Kawasaki KZ 550 LTD
1987 BMW 325is
