ARD MAGNETO HELP.....
  • carksz1b
  • carksz1b's Avatar Topic Author
28 Nov 2011 22:50 - 28 Nov 2011 23:40
#490586
DOES ANYONE HERE HAVE A EXTRA AMPLIFIER BOX FOR CDI ARD MAGNETO,FOR A KAWASAKI Z1?
THANKS CARL
Last edit: 28 Nov 2011 23:40 by carksz1b.
  • Motor Head
  • Motor Head's Avatar
Re: ARD MAGNETO HELP.....
28 Nov 2011 23:22
#490592
Your picture is pretty fuzzy, some circuit on a breadboard. Needs repair? That might be the easiest solution. Whats on the board? Resistors, Diodes, transistors, ??? Replacing those would cost a couple of bucks.
  • carksz1b
28 Nov 2011 23:37
#490597
it looks pretty simply,i tryed replacing the 4 diodes..no help
  • Motor Head
28 Nov 2011 23:40
#490599
I don't want to doubt your work, but did you test the ones you replaced? Put the new ones in with the Cathode in the correct direction?
Whats the Ignition doing, no spark, or weak spark?
  • carksz1b
28 Nov 2011 23:41
#490600
i put them in right ,it has no spark
  • carksz1b
28 Nov 2011 23:46
#490602
carksz1b wrote: i put them in right ,it has no spark
thanks
  • Motor Head
28 Nov 2011 23:47 - 28 Nov 2011 23:52
#490604
So the Mag itself checks out, and the Voltage is lost at the Amp box?
Maybe some info from this old thread can help?
forums.sohc4.net/index.php?topic=14994.0
Last edit: 28 Nov 2011 23:52 by Motor Head.
  • carksz1b
29 Nov 2011 00:15
#490606
thanks all check it out,,i bought it used off ebay,all i no is the 2 wires that come out of the mag to the box have, Continuity
  • DoubleDub
  • DoubleDub's Avatar
29 Nov 2011 00:27
#490608
My guess is the answer to the original question is no.
And since it's no, we're just trying to be helpful.
