I want to turn off the headlight
- bluej58
Re: I want to turn off the headlight
28 Nov 2011 09:46 - 28 Nov 2011 09:49
the occasional time at night when a headlight can be an annoyance...[/quote]
:laugh: You need to elaborate on this shit... :laugh:[/quote]
My bet's on bluej58 planning for that very infrequent experience when you might need to make a quick exit of the main road and go into stealth mode while still running.
Bill[/quote]
I was thinking more like a Drive In Movie...But that is a option too...LOL
:woohoo:[/quote]
Old habits die hard
JD
Bill[/quote]
Old habits die hard
JD
78 KZ1000 A2A
Last edit: 28 Nov 2011 09:49 by bluej58.
- P21
28 Nov 2011 20:35
he going to see your girlfriend when your at work :evil: :evil: :woohoo:
Kawasaki KZ 1000 Police (2002) P21
- bluej58
29 Nov 2011 00:31 - 29 Nov 2011 09:39
You got me all wrong P21, I'm a happily married guy.
I just remember the days when I had a choice
JD
JD
78 KZ1000 A2A
Last edit: 29 Nov 2011 09:39 by bluej58.
- steell
29 Nov 2011 00:53
You might look into the wiring harness under the tank, and you might find two wires there that are connected with a jumper. If there is, and you remove that jumper you can plug in the two wires from the early model switch.
That's the way it is on a 79 KZ750 twin anyway
Worth taking a look.
- fxdl2051
29 Nov 2011 12:39
My only concern besides that of being nailed by a cager, is that if you are involved in an accident and the headlight is found to be disabled the argument "I didn't see him", has some legal credence. You never want to be in a law suit and since a lot of motorcycle/car accidents are big dollar items, you know the insurance companies will do everything they can to dispute your cliam ( I know from experience). After being seriously f'ed/u in a car vs bike accident I go the other way, a 90 watt PIAA headlight with a Kissan headlight modulator. Can't tell you the number of cagers who have commented on that, but at least they see me at the intersections. I'll probably wire a tailight modulator and hopefully something for a ts/ tailight /running light function. Squealing wheels from my 6 are no fun either.
ss^,Ken
ss^,Ken
- bluej58
16 Dec 2011 01:30 - 16 Dec 2011 19:25
OK ,
it looks like I have to follow the brown wire from the engine kill switch to where it splits into 2 brown wire's.
Then I need to interrupt the brown wire that goes to another split that turns into a blue and white wire and a brown and white wire, which eventually head to the lights.
I think :woohoo:
This is based on cross referencing the wiring diagram's for an A-1 and A2A , all the colors seem there.
It will be a couple of months before I find out, I'll let you know.
JD
I think :woohoo:
JD
78 KZ1000 A2A
Last edit: 16 Dec 2011 19:25 by bluej58.
- loudhvx
16 Dec 2011 17:38
Be careful with that brown wire. If you cut it at the wrong place, you can burn up the entire electrical system... coils, lights, regulator, rectifier. Make sure you are only cutting the brown wire at the branch that feeds the BRN/WHT and BLU/WHT wires. It's a very small branch on the diagram and appears to be drawn in the handlebar switch unit. If you cut the brown wire feeding the switch unit, you may lose ignition as well, so it has to be that little branch between the kill switch and light wires.
You are safer interrupting the BRN/WHT and BLU/WHT wires with a double-pole, double-throw switch (DPDT). But it will work as you described, at least according to the diagram I have for 78 KZ1000 A2 and A2A.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- 893cv
17 Dec 2011 02:38
No eBay APP ID and/or Cert ID defined in Kunena configurationTry this switch, its a simple plug and play.
1980 kz1000 LTD
1978 Z1R
1978 Z1R
- bluej58
04 Apr 2012 23:24 - 04 Apr 2012 23:26
As it turns out all I had to do was swap the 78 switch control and wire harness that runs through the bars with a 77 control and wire harness that has the off/on switch , the wires were already spliced and is a perfect color match, just plugged it in
Not only the head light goes off but so does the running lights and the gauges too.
78 KZ1000 A2A
Last edit: 04 Apr 2012 23:26 by bluej58.
