I want to turn off the headlight
  • bluej58
  • bluej58's Avatar Topic Author
27 Nov 2011 16:29
#490373
And the running lights too.
My 77 kz650 had the switch and so does my 77 kz1000 parts bike, made in Japan.
I suppose it is an American thing because my A2A was built in Nebraska and is automatic.
Any way I liked having the option of turning them off.
Is it as simple as interrupting the common black and yellow ground wire to the lights
or is it a major PITA.
JD
78 KZ1000 A2A
  • MFolks
  • MFolks's Avatar
Re: I want to turn off the headlight
27 Nov 2011 16:50
#490376
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
If your bike has the Kawasaki supplied "Reserve Lighting System", you'll need to have a double pole switch control both high and low beams on the headlight. The running lights in the front are powered by a blue wire going to both running lights.
I suppose a three pole(or a four pole, with an unused pole), double throw switch will meet your needs, controlling the headlight & running lights, now the question is, where to mount it?
  • bountyhunter
  • bountyhunter's Avatar
27 Nov 2011 17:32 - 27 Nov 2011 17:35
#490387
It's doable but most states require headlight on for motorcycle operation. In California, it's flatly illegal to modify the lights at all so you have to have whatever it came from the factory with.
My '79 has the headlight always on (no switch) but the handlebar cast assembly still has the writing on it for "lights" and "on" and "off" where the switch used to be so I guess I just missed the year when it had the switch.
Last edit: 27 Nov 2011 17:35 by bountyhunter.
  • Motor Head
  • Motor Head's Avatar
27 Nov 2011 17:42
#490388
Head Light ON at all times = Safety Measure.
I would leave it On, there are enough bad drivers out there. Don't put the odds anymore in their favor. :ohmy:
  • P21
  • P21's Avatar
27 Nov 2011 17:55
#490389
Motor Head wrote: Head Light ON at all times = Safety Measure.
and i will second that
Kawasaki KZ 1000 Police (2002) P21
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
27 Nov 2011 18:32
#490393
I'll third that, well said.
It saves lives up here in Canada, trust me ;)
However, I did add the option to turn the light off for the addition power when starting. I am diligent in turning the lights back on as soon as the engine is started. Lights on means you're seen.
Theres a circuit design by Lou D. (loudvhx) here somewhere that shows how to have the lights come on automatically after the engine starts. Try the search/google or maybe he'll pop up here and set you up.
Good luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • bluej58
27 Nov 2011 19:52 - 27 Nov 2011 19:52
#490411
Thanks guys,
The reason was for starting and working on the bike and the occasional time at night when a headlight can be an annoyance .
I have the switch housing off the 77 and it has the off/on for the lights, I was hoping for an easy mod.
If it's to much of a hassle I have bigger fish to fry.
I'm always a big fan of safety and having the lights on while riding and wearing a brain bucket is a givin
JD
78 KZ1000 A2A
Last edit: 27 Nov 2011 19:52 by bluej58.
  • Motor Head
27 Nov 2011 21:11
#490424
bluej58 wrote: Thanks guys,
JD
If you have the switch housing, then just test it with an Ohm meter. It probably does what your first thought was, Interrupts the ground. Maybe the connector is the same? Or the wires can be taken out of their position in one connector and put into the other, to mate them?
  • bountyhunter
27 Nov 2011 21:39
#490431
JD
I have a relay system on mine that disconnects all the lights when the starter button is depressed. Definitely increases battery life.
  • TeK9iNe
  • TeK9iNe's Avatar
28 Nov 2011 00:08
#490456
bluej58 wrote: the occasional time at night when a headlight can be an annoyance...
:laugh: You need to elaborate on this shit... :laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
28 Nov 2011 00:20
#490458
My bet's on bluej58 planning for that very infrequent experience when you might need to make a quick exit of the main road and go into stealth mode while still running. B)
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • elfmagic17
  • elfmagic17's Avatar
28 Nov 2011 01:32
#490481
Bill
I was thinking more like a Drive In Movie...But that is a option too...LOL :P :woohoo:
Kenny Hicks
74 Honda CB550
