78' kz650 no fire on 2&3
- mcoyle05
21 May 2006 13:35
im going to start from the begining.
i bought this bike about 2weeks ago not running from a guy who claimed it had points trouble. never having owned a bike b4 this point i used what i knew about cars in order to get the bike running. replaced the battery - cleaned the carbs - checked all plugs (worked) - gave the bike a full safety inspection - and then fired the bike up. the bike ran fine for a week and then quit fireing on cylinders 2&3
here is what i did:
checked spark plugs - working
checked for fire from wires, 1-4 gets nice brite spark while 2-3 gets what looks like a static spark (obviously not enough to fire)
when i opened the points caseing i noticed that on 1&4 you cannot see any spark until the advance kicks in, and on 2&3 i can see spark all the time
this is all the information i have and i am stumped the bike will still start and run fine on just 2 cylinders. any help would be nice
here is what i did:
- steell
Re: 78' kz650 no fire on 2&3
21 May 2006 14:26
Generally, when you can see the points sparking all the time it means the condenser is bad.
- mcoyle05
21 May 2006 14:46
well when i say all the time i dun mean a constant arc.. i mean i see it spark alot compaired to the other point that never sparks except when the advance kicks on (4500 - 9000 rpm)
sorry about being unclear
