650E1 rectifier problem
- Onetype
14 Nov 2011 15:02 - 14 Nov 2011 15:09
I have a 5 wire rectifier that isn't charging. According to my wiring diagram, the black wire connects to the yellow/red trace wire off my relay, which feeds into the ground system (black/yellow trace) to the negative side of battery.
When I try and hook up the wire, it pops/sparks blue, and immediately gets HOT. I've even tried taking the black wire off the rectifier straight to a ground and no change. At one point my old battery was connected backwards and left overnight (yeah, I know...). I'm thinking it fried the rectifier. Any thoughts? I've found a source for new ones, but they are expensive (over $100), and I can't find one on OregonMotorcycles. Any suggestions?
Last edit: 14 Nov 2011 15:09 by Onetype.
- Onetype
Re: 650E1 rectifier problem
14 Nov 2011 15:20 - 14 Nov 2011 15:31
Also, mine says sh222-12 9.9 What is the 9.9, as most of the ones I am seeing are 0.2 or different. Do I need another one that says 9.9 or no?
Last edit: 14 Nov 2011 15:31 by Onetype.
- T_Dub
14 Nov 2011 15:42
Go to this page:
www.oregonmotorcycleparts.com/VRRPM.html
You want the part number VRRPM2-KZC. It's $92.
As I look further, this might not be a direct fit. You might want to buy the one that just has leads and wire it in yourself.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- Onetype
14 Nov 2011 21:10 - 14 Nov 2011 21:10
Found one on ebay for $36. sh222-12 0.2 Hopefully it fixes my problem. If not, atleast I can better diagnose it.
Last edit: 14 Nov 2011 21:10 by Onetype.
- T_Dub
14 Nov 2011 22:33
Yup, hopefully so. You have a service manual? If so, go through and check your electrical system. There are a bunch of values you can check. Also go through your wiring to make sure you havent fried any of the actual wiring.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- Onetype
17 Nov 2011 17:45
Well, I got the new one on during lunch and the bike is keeping a steady 13.50-13.60 volts at idle. Hooked up my tail light just to give it a little drain and it appears good.
- T_Dub
17 Nov 2011 17:48
Sounds good! Happy that you worked it out.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- douglaskgoff
