almost updated
  • locolobo
  • locolobo's Avatar Topic Author
almost updated
08 Nov 2011 23:05 - 08 Nov 2011 23:10
#487711
ok this is what i have....i think im gettin there....
right leg side of bike.....blk/yel with inline fuse connected to frame
neg connected to batt
5 wire connector blk/yel,wht/grn,brown,lite grn n white...not connect to anything
2 orange wires to vshaped male connector not connected to anything
left leg side of bike....wht/red conn to dble female bullit coming off positive of starter relay
wht/lite blue,yel/blk double female bullit not connected
yel/red female coming off starter relay connected to yel/red male
blk male bullit connected to blk female
yel/blk coming off wire cluster from headlight etc connected to frame
blk from starter connected to starter relay
thats what i have...and for s...s and giggles how do i remove the bulb inside my speedometer...its blown out....
plus im gona go with inline fuse holder instead of glass fuses.
this is all i hope...and guys i want you to knw i really appreciate all your help as this is the first major undertaking ive ever done and i knw absolutly nothing about electrical...she's painted and cleared and tins back on...now just to get her started...
1983 kz750 ltd k1 with belt...
peace be with you all...
doug
locolobo
Last edit: 08 Nov 2011 23:10 by locolobo. Reason: repeated myself on some issues
  • Motor Head
  • Motor Head's Avatar
Re: almost updated
08 Nov 2011 23:18
#487715
Hey can you get some photos of all this, it may help reference where it is all at. See the size of the wires, etc.
The following user(s) said Thank You: locolobo
  • locolobo
Re: almost updated
11 Nov 2011 15:22
#488056
ok...i got it wired power to everything except running lite which i didnt ground i used jb weld to mount to my sissy bar that will be corrected....but when it fired up after some churning and grinding....it spit,sputterd,backfired and kept cutting off...im asssuming i dont have the floats on the carbs adjusted right...only 2 carbs 83 kaw750 k1 ltd belt....the started is fine i had that checked....
just want to thanks and i appreciated everyones help and suggestions if it wasnt for you guys id still be messing with the wiring....now to troubleshoot carbs....
peace to all
locolobo
  • locolobo
Re: almost updated
28 Nov 2011 01:12
#490472
reply to motorhead....
locolobo
