low fuel sensor
- abrambila
low fuel sensor
07 Nov 2011 18:31
1978 KZ650 D1
I've got a question regarding the sensor that screws into the fuel tank and hooks up to the light on the tach that lets you know you have low fuel. Is there a way to test if the device is functioning? I tried removing it from the gas tank and hooking it up directly in the air, but it didn't do anything. Here's a link to a photo of the part: www.flickr.com/photos/68421321@N08/6323240449/
If it doesn't work is there a way to repair it, or do I need to buy a new one?
Thanks!
Thanks!
1978 KZ650 D1
- Motor Head
Re: low fuel sensor
07 Nov 2011 20:10
Maybe reading through this thread may enlighten you.
www.kzrider.com/forum/4-electrical/47035...ght-switch-or-sensor
Last edit: 18 Feb 2013 17:56 by martin_csr.
