LED's vs. regular bulbs I was thinking
  • gengomerpyle
  • gengomerpyle's Avatar
Re: LED's vs. regular bulbs I was thinking
11 Nov 2011 19:38
#488088
how hard was it to hook up the new cluster to triple trees and did everything plug into existing wiring?
otakar wrote: I went from this.
Attachment DSC01003.JPG not found
Attachment DSC01385.JPG not found
To This.
Attachment DSC01032.JPG not found
Attachment DSC01683_2011-11-11.JPG not found
Attachment DSC01691_2011-11-11.JPG not found
Notice that the center indicator lights are gone and that there is a row of corresponding color LEDs under the gauges. The end two "double" yellow LEDs being my turn indicators. All internal lighting are also LEDs.
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
  • otakar
  • otakar's Avatar
11 Nov 2011 19:42 - 11 Nov 2011 19:44
#488089
I had to make a bracket and NOTHING plugged in. The light bar is custom made so it had to be wired in. The only thing that plugged in was the fuel gauge. I went from a mechanical tach drive to an electronic tach, so that had to be wired in and so on.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 11 Nov 2011 19:44 by otakar.
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
11 Nov 2011 21:26
#488097
I just noticed your clock next to your clutch perch. That's pretty rad! ;)
You should make a nice base for it to fit with the gauges!
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • Topper
  • Topper's Avatar
11 Nov 2011 21:41
#488102
I've been considering going led as well. I've read in a couple places that you should use colored leds that match the lens color, except the tail light.
Is that right and if so why? I'd figure a bright white led would produce the most light and the plastic lens will do its job regardless of whether the bulb is incandescant or led.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
  • otakar
  • otakar's Avatar
11 Nov 2011 22:26
#488107
Actually RED LEDs are the brightest. But to answer your question. You are right. Just go with white LEDs. They have a bit different light dispersion pattern so you might have to do some reflector tweaking, depending on your taste and what you want to achieve.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
11 Nov 2011 22:28
#488108
mtbspeedfreak wrote: I just noticed your clock next to your clutch perch. That's pretty rad! ;)
That watch has been there for about 5 years. I have never taken it off.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Topper
  • Topper's Avatar
12 Nov 2011 00:20 - 12 Nov 2011 00:31
#488119
otakar wrote: You are right. Just go with white LEDs.
Thanks. Regarding the type of flasher relay needed, the CF12ANL you mention is square and mine's round. Is that going to matter? Will I need to rig some sort of connector or bracket?
I've seen some LED compatible 2 pin flasher relays on other sites that look to be the same size and shape as mine, but in their product descriptions they say things like "built in resistors". Does that mean these are the wrong kind of flasher relay? Will they just make up for the resistance I'm reducing by swapping in LEDs?
1979 KZ750 Twin
Last edit: 12 Nov 2011 00:31 by Topper.
  • mtbspeedfreak
12 Nov 2011 00:40
#488122
Topper wrote: Thanks. Regarding the type of flasher relay needed, the CF12ANL you mention is square and mine's round. Is that going to matter? Will I need to rig some sort of connector or bracket?
I was able to carefully pull my round mount apart from the round flasher and the square CF12 fit with a little bit of stretching and a zip tie for added security. B) I highly recommend the CF12 compared to anything else.
2000 ZRX 1100
  • bountyhunter
  • bountyhunter's Avatar
12 Nov 2011 04:01
#488137
otakar wrote: Actually RED LEDs are the brightest. But to answer your question. You are right. Just go with white LEDs.
I think you should get the color that matches the lense (amber front, red back). If you put a white LED behind a colored lense you are wasting light and brightness. The colored lense filters out all the light not the color of the lense.
  • mtbspeedfreak
12 Nov 2011 06:06
#488143
BH, yes that is correct. Keep in mind your license plate light though... it'd drive me nuts to have a red license plate light (and probably illegal too...).
2000 ZRX 1100
  • otakar
  • otakar's Avatar
12 Nov 2011 10:17
#488151
Stay with white. Available amber bulbs are actually quite dim. also, if you use them behind an amber lens, the light winds up being extremely orange. To the point of being annoying. I have tried it and I don't like it. It is one thing if the lens on the light is clear, it is another if the lens is colored. If thye lens is colored it is intended to be used with a white bulb.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Topper
  • Topper's Avatar
12 Nov 2011 11:00
#488154
No eBay APP ID and/or Cert ID defined in Kunena configurationThanks for all the help on led bulb color. I'm going to try white and see how they look.
Topper wrote: I've seen some LED compatible 2 pin flasher relays on other sites that look to be the same size and shape as mine, but in their product descriptions they say things like "built in resistors". Does that mean these are the wrong kind of flasher relay? Will they just make up for the resistance I'm reducing by swapping in LEDs?
What about the LED flasher relay? From what mtbspeedfreak says the square CF12 one can be made to work. But if one of these round LED ones fits better, I'd rather go with it.
Here's an example of what I'm talking about. There's a line in the description that says "inbuilt resistors" that makes me worry it's not really what I need.
1979 KZ750 Twin
