- Thank you received: 7
Finally found a decent fuse box:
- riverroad
- 1980 1000LTD B4
31 Oct 2011 11:39 - 31 Oct 2011 11:41 #486246
by riverroad
Finally found a decent fuse box: was created by riverroad
I'd seen other threads on the subject, and I even bought a blade type fuse box, but the way the terminals are arranged on each side of it, I couldn't figure out a way to mount it without moving a bunch of stuff and fabing brackets and such.
But I found this website that held the answer: www.easternbeaver.com/Main/Elec__Product...ers/fuseholders.html
It's the Metri-Pack 280 3 Fuse Fuseholder for ATM Type Mini Blade Fuses.
Weather tight and it holds the mini blade fuses, and it fits right where the stock unit was.
Only problem is, the dude wants a twenty dollar minimum purchase. So I bought two, some extra fuses and some extra bullet connectors for other stuff.
Another thing is, the crimp terminals don't form very well with my cheapo Autozone wire crimpers, so bear that in mind.
Last edit: 31 Oct 2011 11:41 by riverroad.
- clutch
- I wish I had a tad more patience to do it better!
- Thank you received: 12
31 Oct 2011 12:17 #486251
by clutch
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
Replied by clutch on topic Finally found a decent fuse box:
Nice! Thanks for the link. I may get a couple of these myself
Wish List:
Z1 (need I...
- Thank you received: 797
31 Oct 2011 15:47 #486307
by 531blackbanshee
Replied by 531blackbanshee on topic Finally found a decent fuse box:
riverroad would you mind postin some pics of your install?
i would like to do this myself.
are you interested in selling the extra one you bought?
- Topper
- Thank you received: 133
31 Oct 2011 16:30 #486318
by Topper
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
Replied by Topper on topic Finally found a decent fuse box:
That looks perfect! Please post some photos of your conversion.
Oh and noob question here, but what's the two different versions? 18-16 AWG and 14-12 AWG
Is that the wire gauge? And if so, anybody know what we've got in these old KZs?
1979 KZ750 Twin
- riverroad
- 1980 1000LTD B4
31 Oct 2011 16:37 #486321
by riverroad
Replied by riverroad on topic Finally found a decent fuse box:
Well, I haven't taken any pics of it yet, but there really isn't much to look at when trying to compare the old and new. They're both the same general size and shape, and it fits in the same place the old one did. But I haven't figured out how to attach it to the rubber thingy yet. I might take some pics tonight when I get home, but I'm working hard on my 54 F100 right now too. (I hate body work!)
Think I'll keep the extra one though. Might add some extra circuits one of these days, Heated grips, stuff like that.
- Thank you received: 1656
31 Oct 2011 17:47 - 21 Feb 2013 17:59 #486332
by martin_csr
Replied by martin_csr on topic Eastern Beaver Fuse Box zBeaverZ zFuseZ
Last edit: 21 Feb 2013 17:59 by martin_csr.
- 750steve
31 Oct 2011 19:04 - 31 Oct 2011 19:04 #486348
by 750steve
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Replied by 750steve on topic Finally found a decent fuse box:
Nice link!! I see a couple of things on that site i've been looking for! This should kill my distrubution & grounding issues in 1 tidy go!
www.easternbeaver.com/Main/Products/Fuseboxes/PC-8/pc-8.html
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 31 Oct 2011 19:04 by 750steve.
- MFolks
- Thank you received: 540
31 Oct 2011 19:25 #486353
by MFolks
Replied by MFolks on topic Finally found a decent fuse box:
Wire Termination Insulation & Sizes
Terminal Insulation Color Wire Sizes
RED
22-18 gauge wire
BLUE
16-14 gauge wire
YELLOW
12-10 gauge wire
The ring terminal holes comes in many sizes, from #4 up to 1/2" in most cases, it's a matter of finding the tightest fitting hole to fit the fastener for the termination.
American Wire Gauge(AWG) is backwards to what many people think; that is 22 gauge is many times smaller than 10 gauge even though the number is bigger.
If you need information about heatshrinkable terminals, or splices(butt connectors) and tools, just ask....
RED
22-18 gauge wire
BLUE
16-14 gauge wire
YELLOW
12-10 gauge wire
- MFolks
31 Oct 2011 19:34 #486356
by MFolks
In reply to what he wire sizes are used in the Kawasaki's, it depends on the current(amp) needs.
Most lighting circuits are at least 18 gauge in size, but can be 16 gauge(like for the brake/running light circuit). Battery cables are probably 8 gauge for the high current draw when starting turning the engine over.
The white with red strip wire from the regulator/rectifier to the battery is probably 12 gauge in size.
I'd say using at least 18 gauge for lighting circuits is a safe size. with 16 gauge if more current draw is anticipated. 12 gauge for most high current draws in 20 and 30 amp fuses should be safe.
- 750steve
31 Oct 2011 19:35 - 31 Oct 2011 19:35 #486357
by 750steve
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Okay, MFolks, is that box in the link above a good solution for me? I'll be running a Headlight, Tial/stop light, horn? I'll be running all the gnd/pwr wires from inside a fabricated alu box under the seat as i want to keep the wiring out of sight. There will also be wires to & from the clock (an Acewell clock
www.acewell.co.uk/Acewell%20Speedometers/ACE-2xxx/index.htm
) & a nautral & oil light on the clock
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 31 Oct 2011 19:35 by 750steve.
- MFolks
31 Oct 2011 19:57 #486360
by MFolks
Depends on how weather protected it is, as moisture will play havoc with electrical circuits.Myself, I like the fuse blocks/holders with some protection from splashes/drips.
Here's another website about wiring on the bike using relays:
www.canyonchasers.net/shop/generic/relay.php
Marine rated fuse blocks(not sure if the circuits are seperate for motorcycle use)
www.iboats.com/Blue-Sea-SafetyHub-150-Fu...8312--view_id.729804
www.iboats.com/Seachoice-ATO-ATC-Fuse-Bl...748312--view_id.2901
www.iboats.com/Screw-Terminal-Blade-Fuse...8312--view_id.163740
www.google.com/products/catalog?rlz=1T4D...AQ&ved=0CIQBEPMCMAU#
bluesea.com/category/81/21
The following user(s) said Thank You: 750steve
- MFolks
31 Oct 2011 20:00 #486362
by MFolks
Check the bike's wiring diagram(or if possible open up the back of those fuse blocks with backs to check for jumpers or buss bars tying several circuits together).Kawasaki's did this to reduce some of the wiring.
