Regulator/Rectifier
- andrew12159
Regulator/Rectifier
19 May 2006 14:23
OK here we go again. I just tested my coil with an ohm meter and it tests OK. I am going to replace the wires with new ones as I have already got the old ones seperated from the coil. Next question.....I tried to test the regulator/rectifier with the ohm meter and followed the directions in the kawasaki manual. The problem is I am getting good readings on way but the other I get a OL(overload) reading. The ohm meter is an automatic one as you don't have to switch between 1k 100k and so forth. does this mean it is toast? Anyone have one for a '78 750B3? Thanks.
- steell
Re: Regulator/Rectifier
19 May 2006 16:42
I think there is still one on the 78 frame out in the garage, I'll have to go look.
- andrew12159
20 May 2006 08:08
OK, let me know I will get you payment if you want to let it go.
- steell
20 May 2006 14:59
Nope, it's no longer on the frame, it may still be in the garage but it's in a horrendous mess right now as I'm re-organizing and trying to make some room
- andrew12159
20 May 2006 17:21
OK, Thanks. Anyone know of one that can be used in its place? Its a Shindengen SH221-12 8.5.
- andrew12159
20 May 2006 18:02
I just tested it with my ohm meter. I have the factory service manual which says with the meter set to x1, ohm meter + to yellow lead on reg/rec and - on meter to black on reg/rec. It states that I should get a reading of less than 20 ohms. I am getting a reading of .800-.900 ohm with a little "m" next to the numbers. anyone have any idea. The other test seems in spec. I am supposed to read more than 100k ohms I am getting approx. 130k. again with the little "m" after the numbers.I should have paid more attention in science class!
- steell
20 May 2006 19:12
"K" is thousands and "M" (or "m") is mega ohms, as in millions
It don't sound good.
I can't remember, do you have three yellow wires coming off the alternator and going to the regulator, or two?
- andrew12159
- steell
20 May 2006 21:35
It's two yellow wires going to the alternator, the other wire goes somewhere else.
The part number for the reg/rec is 21066-029, and there are several members that have the cross reference cd, so hopefully someone will post a list of other models that use the same one.
You can also use the parts diagrams at www.buykawasaki.com to compare part numbers.
1978 KZ650B2 uses the same one. (still looking).
1979 KZ650 uses the same one.
1979 KZ400 uses the same one, and I quit
I'll try to look later to see if I can find one in the garage.
Post edited by: steell, at: 2006/05/21 00:46
- Grantl
- KZRider is Da Bomb!!!
21 May 2006 09:31
I was taught that (K) ohms is in thousands and that (M) ohms is micro ohms as in less than 1.
I have been doing the same tests on my regulator/rectifier for my 81 KZ1000M CSR model. The manual says to check resistance from the red/white wire to the (3) yellow wires. The resistance is approx 4 ohms. Same with checking the Black to the 3 yellows. The manual says that if you reverse the polarity of the meter leads to the same connections you should see a difference of at least 10 times the value. I get a reading of (OFL) which means out of field limits-- or infinity. If you are getting the same type results as these you could conclude that the regulator/rectifier is good.
best of luck.
Grant.
best of luck.
Grant.
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
1990 550 Zephyr
1994 KZ1000 P
- steell
21 May 2006 10:11
Nope, "M" is mega ohms as in millions, micro ohms (never seen a meter that could measure them, but there probably is one) are "u"Ohms.
Obigatory link:
Measuring resistance
en.wikipedia.org/wiki/Ohm
Found a meter that will read micro ohms, but it costs $2,695.00 :woohoo:
www.omnicontrols.biz/products.asp?recnumber=1429
Post edited by: steell, at: 2006/05/21 13:35
Obigatory link:
Units of ohms, kilohms (103 Ω) and megohms (106 Ω) are used in electronic design documentation. On schematic diagrams kilohms are abbreviated "K" and megohms are abbreviated "M". Thus, 33 kilohms would be rendered as 33K, and 5.1 megohms would be 5.1M. Values less than 1K are rendered without any symbol following the number, so 680 ohms would simply be shown as 680.
- Grantl
21 May 2006 12:02
Steel,
you are correct. After I posted I looked it up (my bad)
Grant.
Grant.
1981 KZ1000 CSR
1990 550 Zephyr
1994 KZ1000 P
1990 550 Zephyr
1994 KZ1000 P
