bare bones
  • locolobo
  • locolobo's Avatar Topic Author
bare bones
24 Oct 2011 21:18
#485129
looking for a bare bones wiring diagram for a 83 kz750 ltd k1 with belt drive and electronic start...no points...i guess i put that right...lol....would the diagram for mattylight work for the 750?
thnx in advance :sick:
locolobo
  • clutch
  • clutch's Avatar
  • I wish I had a tad more patience to do it better!
Re: bare bones
24 Oct 2011 22:32
#485149
There should be a wiring diagram or two in that thread that will work for you. I just did a complete rewire of my 82 750-4. I don't know if it would be considered bare bones, but it is a simpler setup, with some of the nonsense removed. You're welcome to bounce any questions off me if you need some help. And I'm sure at some point Loudhvx and MFolks, our resident wiring gurus, will be chiming in on your thread here to help you out as well.
~Clutch
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
The following user(s) said Thank You: locolobo
  • clutch
  • clutch's Avatar
Re: bare bones
24 Oct 2011 22:37
#485152
PS: If you use this thread as your project thread, I'm subscribed, so just post questions here and I will be on to answer them as I can :)
Wish List:
Z1 (need I...
  • MFolks
  • MFolks's Avatar
Re: bare bones
24 Oct 2011 22:49
#485156
If you need information about the best electrical splices,tools for wiring and other related electrical questions, just ask.....
  • loudhvx
  • loudhvx's Avatar
Re: bare bones
25 Oct 2011 13:08
#485274
I posted it. I think it's on page 12?
  • locolobo
Re: bare bones
25 Oct 2011 19:40
#485323
thanx man,i appreciate it...i do have a question for u.....i started marking and inspecting my harness and everything else....alot of the contacts are correded n what looks like rust....will be spraying them with contact cleaner....but can i use a starter/kill switch from a 94 honda shadow on my 83 kz750 belt?
thanx
locolobo
  • MFolks
  • MFolks's Avatar
Re: bare bones
25 Oct 2011 19:49
#485324
The best cleaner I've found for motorcycle switches & connectors is a brand called "De-Oxit" www.deoxit.com is their website and it's available at Radio Shack Stores and other electronic supply places.
Cleaning Motorcycle Electrics
Get some of the De-Oxit electrical contact cleaner and figure on spending a good day going from the front of the bike to the back. It’s a plastic safe cleaner/preservative. www.deoxit.com is their website. Or use any plastic safe electrical contact cleaner(NOT WD-40 !).
On the older Kawasaki's, a majority of electrical connectors are inside the headlight housing requiring removal of the headlight, then the fun begins.
Do one set of electrical connectors at a time to avoid mixing up what connects to where. Usually disconnecting, spraying with De-Oxit and reconnecting is about all you'll need.
However, when encountering the green crud of corrosion, a brass wire brush may be needed on the pins you can reach. Some 400-600 grit wet and dry sandpaper strips rolled into a tube should reach the male and female pins in the more difficult to clean connectors.
Smoker’s pipe cleaners, cotton swabs and wooden toothpicks work as cleaning aids.
Really small electrical connectors may require the use of a welders tip cleaning tool assortment.
Most pins in the connectors are coated with a thin plating of tin, and others may be nothing more than copper or brass.
If moisture is added, the resulting corrosion lowers the voltage/current being carried causing dim lights, slow engine cranking, slow turn signal responce and lower input voltage to the ignition coils resulting in weak spark.
The left and right handlebar switch pods will need attention too as they have circuit functions like turn, horn, run/stop, and start.
Usually a spritz or two with actuation of the switch is about all needed for these switches unless corrosion is detected and then careful disassembly is required.
The ignition switch may or may be not sealed to allow spraying the internal contacts. I urge caution if attempting to open this up as springs, and ball bearings may fly out never to be seen again!
If your bike has the older style glass tubed fuses, I suggest replacing them as vibration can cause internal failure. AGX is the type used, and most auto parts stores can get them for you.
Clean the fuse holder clips, looking for signs of overheating(discolored insulation, signs of melting). I use metal polish on a cotton swab, followed by spraying another clean swab with the De-Oxit and then rubbing the inside of the fuse clip.
All battery cables must be clean and tight for maximum current transfer. Check the cables going from the Negative(-) battery terminal/post to the engine mounting bolt
Also the one going from the Positive(+) terminal to the starter solenoid and from there to the starter motor.
If any battery cable feels ”Crunchy” when flexed, replace it as possible corrosion is inside the insulation.
Each "Bullet Connector" will have to be sprayed to ensure good connectivity, especially the ones going to the energizing coil of the starter solenoid.
The alternator output “Bullet Connectors” are usually behind the engine sprocket cover and will need inspecting and cleaning too.
The turn signal light sockets will benefit from a spritz from the contact cleaner along with the tail light/brake light socket.
Some brake light switches can be sprayed on the actuating rod, with the spray running down inside to the electrical contacts, others may be sealed requiring replacement if the switch is intermittent in operation.
Some people put the Di-Electric Grease on cleaned terminations/connectors, I don’t, as I’ve read/heard it can cause problems when it gets hot, actually insulating the connections, so the choice is yours to use or not.
Why WD-40 Should Not Be Used On Motorcycle Electrical Items.
For many years, I was proponent of the use of WD-40 on fuse clips, fuses, switches and connectors. After hearing of other peoples experience with intermittent and sporadic activity, I shrugged it off as maybe they did something wrong in the application of the product.
It wasn’t until the time I rode my 1982 GPz1100 B2 model to downtown San Diego that I encountered the problems others had gone through.
After concluding my business downtown, I walked to where my bike was parked, turned the key to unlock the forks, and prepared to start the engine. The key was in the "On" position, yet I had no lights in the dash panel, the fuel pump was not running(I have FI), and the horn and tail light were not working.
Puzzled as to why nothing electrical was happening, I remember my earlier conversations about how WD-40 will over time become a non-conductor(more like an insulator). I had some pieces of 400 and 600 grit sandpaper in my tool kit and with them was able to scratch away the coating from the WD-40 on the fuses and clips.
After removing the insulating film, the bike started and ran like it should. Since that time, I’ve told people about the problem with WD-40. If you must use a contact cleaner, I recommend getting some "De-oxit" from Radio Shack Stores or any good electronic supply store.
  • loudhvx
  • loudhvx's Avatar
Re: bare bones
25 Oct 2011 22:27
#485358
I would expect the kill and start switch from a modern bike to work. But do you have the color codes, or better yet, a wiring diagram for the Honda?
If you don't, you could probably figure it out with an ohm meter, pretty easily.
  • locolobo
Re: bare bones
26 Oct 2011 19:05
#485498
no...as soon as get model and def yr off the trash bike..i will look it up...by the way will the diagram u did for mightyflite....splg.....work for my 83 kz750 k1 ?
thanx my friend
locolobo
  • locolobo
Re: bare bones
26 Oct 2011 19:07
#485499
would the brass starter relay from same honda to kaw...i guess i would have to check color on both to see which wire is which>?...im a rookie at this stuff...but im learning alot on my own and u guys..plus the manuals....appreciate it thank you
locolobo
  • loudhvx
  • loudhvx's Avatar
Re: bare bones
26 Oct 2011 19:47
#485507
I don't remember the details on Mattylight's bike, but I put up a diagram for your specific bike already, on the last page of the Mattylight thread.
  • locolobo
Re: bare bones
28 Nov 2011 01:22
#490477
didnt you have a diagram on how to make your own igniter?if you did could you point me to it , thanks....i knw im a pain but im newer than a newby....
locolobo
