coil and plug problem
- b4schroer
19 May 2006 09:00
I have a 79 KZ 650. I replaced the original coils with the Green ones last year. My problem is that I'm not getting a spark out to the plug. So it may be the wires, it may be the coil. How to I check the coil to be sure it is ok? I have an ohm-meter, and I know there is a way to figure by testing the resistance. Additionaly, if the coil tests out to be ok, is that for sure a wire problem or could there be a problem with the coil outpur so to speak?
THanks
THanks
- KZ_Rage
- Kentucky Bourbon Barrel Ale
Re: coil and plug problem
19 May 2006 09:08
Just 1 or all 4 are dead?
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
- OKC_Kent
19 May 2006 09:28
Has your bike run at all since you replaced the coils?
Cashion, OK
78 KZ650 B2 85,000+ miles
- indykaw77
19 May 2006 09:32
First....get yerself a manual. A Kawasaki Service manual would be ideal, but a clymer will help you out as well.
I know in the Clymer their are troubleshooting procedures for primary and secondary ign circuits.....how much VDC and impedence between such-and-such contacts and stuff like that there. (Dont have my book in front of me, so cant give you any examples....sorry).
:whistle:
Somebody will chime in with a procedure I'm sure, so in the meantime...find a source for a manual. Well worth whatever $$ you spend on it!
:whistle:
Kawasaki Motorcycles...because cars lean th wrong way!
- Old_Fart
19 May 2006 21:00
If only 1-4 or 2-3 check the points and condensors. If they look/check ok, then check the coils by primary and then secondary OHMS. Primary is checked at the power leads - should be around 16 - 20 KOHMS. The secondary is at the plug wires - should be whatever is marked on the coil - 4 - 6 OHMS.
Good luck
Good luck
- steell
19 May 2006 21:13
Old_Fart wrote:
Actually you have those numbers backwards, 2-4 ohms on the primary side (where the points connect) and 16k-20k ohms on the secondary side (spark plug wires), and check the secondary side without the plug caps on them, then check the plug caps.If only 1-4 or 2-3 check the points and condensors. If they look/check ok, then check the coils by primary and then secondary OHMS. Primary is checked at the power leads - should be around 16 - 20 KOHMS. The secondary is at the plug wires - should be whatever is marked on the coil - 4 - 6 OHMS.
Good luck
