Mounting Emgo Coil on 750 twin
- Topper
20 Oct 2011 00:21
Just got a new Emgo ignition coil for my 1979 KZ750 twin from Z1. It doesn't fit.
Everywhere I look online I see this coil listed as fitting my bike and the description clearly states the mounting bolts are 3.5" (90mm) apart, which they are.
Here's the thing, the mounting points on my bike are 4" (101.5mm) apart.
Surely I'm not the first 750 twin owner to run into this. Any suggestions?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- Motor Head
Re: Mounting Emgo Coil on 750 twin
20 Oct 2011 09:05 - 20 Oct 2011 10:34
If you haven,t already, can you just drill 1 new hole in the mounting bracket. Some of the coil brackets have two holes.
The Emgo coil I have has the 3 1/2" spacing for the bolt holes. I think it was sold as to fit the points fitted 4 cyl bikes.
Last edit: 20 Oct 2011 10:34 by Motor Head.
- Topper
20 Oct 2011 11:57Motor Head wrote: If you haven,t already, can you just drill 1 new hole in the mounting bracket. Some of the coil brackets have two holes.
I don't want to drill holes in the bracket unless I absolutely have to. I'm not even sure that will work as 3.5" puts one of the posts right on the edge of the bracket.
I'll call Z1 today and see if they have a different coil and/or suggestions for mounting.
1979 KZ750 Twin
1979 KZ750 Twin
- Motor Head
20 Oct 2011 12:01
Out of curiosity, have you measured the primary and secondary resistance to see how it compares, Caps in place?
- Topper
20 Oct 2011 12:36 - 20 Oct 2011 12:42
Yep. On the secondary winding with no caps I get about 13 ohms. With caps I get about 24 ohms. And I get 4 ohms on the primary. Just like my old coil.
I'm going to keep the new coil anyway. I figure the old one is OK now but a 32 year old coil is a ticking time bomb.
Plus when I pulled the old coil completely off the bike I could see a place where one of the leads is about to break.
1979 KZ750 Twin
1979 KZ750 Twin
Last edit: 20 Oct 2011 12:42 by Topper.
- Topper
20 Oct 2011 12:41
Called Z1 and talked to a guy in tech support.
He couldn't find an aftermarket coil with the properly spaced mounting points. But he said not to worry about it.
He suggested mounting it with one of the mounting screws and then just rig the other end so it is secure, maybe with some zip ties. The coil doesn't ground through the body so as long as it is secure I'm OK.
Fortunately it's way up under the tank where no one will see it. I might make a little dog leg bracket out of some aluminum stock or I might just zip tie it.
1979 KZ750 Twin
1979 KZ750 Twin
- bountyhunter
20 Oct 2011 18:01I made a short extender piece with two holes in it out of some scrap material.Topper wrote: Just got a new Emgo ignition coil for my 1979 KZ750 twin from Z1. It doesn't fit.
- loudhvx
21 Oct 2011 15:43
I agree, make a little extender bracket out of a strip of steel. Make sure it's steel because it has to transmit magnetic flux to the frame in order to complete the magnetic path through the coil.
Not completing the path will reduce the inductance/impedance of the coil (but not the resistance).
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Topper
21 Oct 2011 16:13
The guy at Z1 seemed pretty sure the coil didn't need to connect to the frame.
But one of the mounting posts on the coil looks like it is supposed to make contact with the leads going to the wiring harness. I went ahead used that mounting point as it was intended.
Then for the other mounting point I used a little strip of aluminum.
It feels pretty sturdy but looks like some idiot who doesn't know what they're doing hooked it up.
Oh wait, that would be me.
1979 KZ750 Twin
1979 KZ750 Twin
- newowner79kz750b1
- 79 kz750b4
21 Oct 2011 16:25
i just drilled another hole, bolted it in and worked fine.
- loudhvx
21 Oct 2011 18:10
It only needs the full magnetic path in order to take full advantage of the coil's potential energy. The bike doesn't need that much spark energy so it should be fine with a slightly reduced amount.
None of the harness wires for the coil are intended to be grounded. There should be no contact between any primary wires and frame ground.
1981 KZ550 D1 gpz.
Other links.
Other links.
