ic igniter
  • opositive
  • opositive's Avatar Topic Author
ic igniter
18 May 2006 18:36
#48315
Help I too have made the relay mod although I cant find the sorce for the coils (my 81j 1000 has green red and black and I just cut one red and ran it in to the relay for the triggger) Q? with the dyna S and relay mod do we need the IC igniter? and what color black or white can I run as the trigger for the relay from the dyna S?
Thoose fat red/yellow wires in the pics look nice and easy!frickn frackn mumble
  • wiredgeorge
  • wiredgeorge's Avatar
Re: ic igniter
19 May 2006 07:31
#48447
OK... you have me thorougly confused. What the heck ignition is in this bike? A Dyna S or OEM IC igniter?
If you have an IC igniter, you can't use a Dyna S and vise versa. If you make clear which type ignition you are using or want to use or whatever, I can help you figure things out as far as wiring the coil relay.
