? On Guages
- scirocco17
? On Guages
18 May 2006 17:57
Can I use any tach, speedo, and gas guage? My guage cluster got smashed when my bike fell off of a trailer and i am poor. to poor to buy the right on on eBay for 100 bucks. it's for an 84 ZN700 ltd shaft, if that helps. Any suggestions are much appreciated! Thanks All!!!
- DanOz7Five0
Re: ? On Guages
18 May 2006 19:45
Quick answer would be no. I think various years have various ratios for the speedo and tach gears. Look
here
to find your bike, then post the part number on the forum and someone will have a cross reference match for you most likely.
- apeman
Re: ? On Guages
19 May 2006 10:57
Also, while many of the guages can be made to work accross the KZ line, I believe your late model may have an electronic tach. That will limit you to looking for others with the same set-up, which will only be the later model years (1983 and newer, maybe?). You could also look at the GPZ guages, since they have the electronic tach as well, I believe.
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
- scirocco17
Re: ? On Guages
19 May 2006 21:30
would this work?
cgi.ebay.com/ebaymotors/TACHOMETER-MINI-...dZ1QQsspagenameZWDVW
or should i get a kaw one?
