aftermarket tail light!! GONNA FREAK OUT
- MFolks
Re: aftermarket tail light!! GONNA FREAK OUT
15 Oct 2011 17:39
1N4003 1 amp diodes are avaiable at any good electronic store,while there, ask how the polarity is marked and how you'd install them in your light(bring it along). I'd imagine soldering will be needed as the diodes have solid wire leads.
If you don't have one, get a 25 watt soldering iron,some Rosin core solder,Rosin flux,rubbing alcohol and a small acid brush for flux cleanup. Never use acid flux or acid solder for electrical work as it will quickly corrode the joint.
If the iron has not been "Tinned"(coated with fresh solder)plug it in and wait a few minutes until it gets to operating temperature, and then unroll a few inches of the solder, and using paper towels or rag, wipe off the fingerprint oils.
Taking the solder, apply a small amount on the heated soldering iron tip untill it is evenly coated, wipe off the excess, and now the soldering iron has been "Tinned" ready for use.
Use the damp sponge or rag to occasionally wipe off the soldering irons tip as the "Tinned" tip will oxidize due to the heat and might require re-tinning.
- Kz luv
15 Oct 2011 22:32
Try Harrison specialties they have a module that may work, it's about $99. I bought one for my tail lights/ turn signals.
www.harrisonspecialties.com/
- bearshawk
15 Oct 2011 23:50
WOW that spendy huh?... i might just put the old one back on for that price...
1978 kz650 sr- long time project/first bike mostly gone
1979 kz659 sr- new acquisition NEXT project GONE
Both 650s combined to make one great bike! with a new powerplant
it is a 79 frame, 78 front end, both 78 wheels and brakes, 78 body work and a 80' 750-4 motor with gpz 750 cams and a kerker and...
- Motor Head
15 Oct 2011 23:57
There is another thread that sounds like the same thing, maybe same light same supplier/ manufacturer?
www.kzrider.com/forum/4-electrical/48308...ng-light-problemleds
