Pickup coils
  • jgc372
  • jgc372's Avatar Topic Author
Pickup coils
11 Oct 2011 19:35
#482595
After removing the stator plate to free up the spark advance I lost first 1&3 than 2&4. The coils appear to be dead. Will a Dayna S system work as a replacement, if the engine already has electronic ignition?
  • MFolks
  • MFolks's Avatar
Re: Pickup coils
11 Oct 2011 19:44
#482596
Did you ohm check the pick up coils?
Ohm Checking Pickup(Pulsing) Coils
The pickup coils on the Kawasaki’s with the factory supplied electronic ignition can sometimes fail or become intermittent due to heat and vibration.
1.Trace back from where the pick up coils are mounted,(under a right side CD sized cover) locate and disconnect a small 4 pin connector. Using a multi-meter set on OHMS and range of 2K, check between the BLUE and BLACK wires(#1 and #4 sparkplug wires) for between 360- 540 OHMS.
2.For #2 and #3 sparkplugs the wire colors will be YELLOW and RED, again 360-540 OHMS. The 550’s,650’s & 750’s may be backwards to the Z1’s,Kz900’s,Kz1000’s & Kz1100’s.
3.If the pickup coils are suspect of failing due to heat, they can be stressed using a hair dryer without the need of the engine running.
4.A replacement set of pickup coils might be obtained from a dealer who serviced the police Kawasaki’s.
5. If replacement pickup coils are not available, your next choice would be to order a Dyna “S” electronic ignition system from www.z1enterprises.com It replaces the IC igniter with a smaller module located where the mechanical ignition advancer was mounted.
6. Checking with Kawasaki.com website has determined that the Pick up(pulsing) coils are available . The pulsing coil # is 59026-1133 and replaces the older # 1002, 1012 which were used from the MKII motors until the 2005 P24.
7.Check the small 4 pin connector that the pickup coils connect to for corrosion/loose pins too.
If you want to spend the $$ for a Dyna, that's your choice, but try new pick up coils if possible as the Kawasakisystem uses less electrical power than the Dyna does.
