Replacement ignition switch for 1983 GPZ 550
  • Archiddeon
  • Archiddeon's Avatar Topic Author
11 Oct 2011 00:57
#482489
I'm trying to find a suitable replacement for the ignition switch on my '83 GPZ 550.
After hunting on eBay for many a month with no luck, I'm just going to get an aftermarket one.
Emgo offers this model www.motorcycle-superstore.com/1/5/86/373...KZ550-GPz-Parts.aspx
The photo looks VERY different from my actual switch (wrong dimensions, wrong wiring), but the guys at motorcycle-superstore say that Emgo assures them it is the correct part and that that is a stock photo. No luck contacting Emgo directly.
Has anyone had any experience with Emgo ignition switches? How are they in terms of matching the stock part, quality, etc.?
Thanks!
1983 GPz 550
1985 Honda CH150 Scooter
1995 Suzuki GS500E
  • MFolks
  • MFolks's Avatar
Re: Replacement ignition switch for 1983 GPZ 550
11 Oct 2011 00:59
#482491
Checked with www.z1enterprises.com ? They of almost anybody, can tell you if the Emgo switch will work.
  • Archiddeon
11 Oct 2011 01:45
#482501
Shot Z1 an email now. They don't have the switch in their KZ550-H2 electrical section, so checking if they may be able to special order it or at least know if it's the right one.
How reliable are Emgo parts? I've seen them offer pretty much everything. Are they good quality?
Thanks!
1983 GPz 550
1995 Suzuki GS500E
  • MFolks
  • MFolks's Avatar
11 Oct 2011 15:24
#482567
A lot of riders are using the Emgo ignition coils and other electrical parts, so I suppose they are reliable...
  • rrings
  • rrings's Avatar
30 Apr 2012 22:47
#518928
just wondering if the switch fit correctly. I'm looking at a 83 gpz 550 for sale without a key. can't start it or check the tank. It better go cheap!
  • Archiddeon
30 Apr 2012 23:20
#518935
I got my replacement switch from www.motorcycle-superstore.com/1/5/86/373...KZ550-GPz-Parts.aspx for < $40
Fits and works perfectly, right down to the steering lock.
It does not come with mounting bolts though ... I used the ones which I had from removing the broken switch.
Hope that helps :)
1983 GPz 550
1995 Suzuki GS500E
