turn signals gone bad.
- bbirch
10 Oct 2011 00:45
I need some help here, i recently painted my kz1000 cop bike and tryed to add led turn signals.
I removed the old light when I painted the bike and added the led strips later. When I used the new turn signals they worked fine but then I turned on the hazard lights and nothing. then turned on turn signals and discovered i lost those somoe how any ideas as to what went wrong?
- MFolks
Re: turn signals gone bad.
10 Oct 2011 00:54
Did you replace the silver can turn signal flasher/relay? A new electronic one from the auto parts store should have your turn signals working again. Make sure you get the same number of contacts on the new flasher as the old one as they come in two(2)and three(3)pin contacts.
The original bulbs had resistance, causing the silver can relay to open and close internal electrical contacts, but the LED's do not have this current draw.
The following user(s) said Thank You: bbirch
- MFolks
10 Oct 2011 00:56
The hazard and turn signal circuits have two seperate flasher cans, you'll need to replace both if you want the system to still work.
- bbirch
10 Oct 2011 01:21
the flasher cans? is it the one on the side near covers. I noticed one on each side but could not properly identify them. I am not good with electrical as im sure you can tell
- MFolks
10 Oct 2011 01:32
There should be two(2) of the cans, one for the turn signals, and the other for the hazard lights. On some bikes they may be close to the battery, usually in a rubber mount for vibration reduction.
Do you have a wiring diagram? it will tell you what color of wires to look for:
cyclepsycho.com/kz1000p/wires1.jpg
- bbirch
10 Oct 2011 10:57
thank you!! i will check it out today after work.
