Can ST gauges be taken apart and repaired?
  • 300kph
  • 300kph's Avatar Topic Author
06 Oct 2011 03:27
#481640
I've seen services that can re-surface the faces of Kawi speedos and tachs...
Never gave it much thought but was always under the impression they were sealed / crimped units. Can they be taken apart and repaired?
Friend has an ST with a broken speedo needle and wants to keep the gauges as it shows original mileage and he wishes to keep the original parts.
Anyone done a Youtube or a written tutorial?
Also curious about re-facing my 78 Z1R as the fade of the gauges will be the only thing that does not appear pristine.
Wonder if they simply decal over them... If so this would probably dim the illumination.
Anyone?
1978 KZ1000 D1 (Z1R)
1979 KZ1000 A3 (MKII)
1979 Honda CBX (Candy Glory Red)
1980 Suzuki GS1100E (Silver)
1980 Suzuki GS1100E (Red)
1978 Yamaha XS1100
1982 Suzuki GSX1100S (Katana)
1984 Kawasaki KZ1100R (Silver)
2004 Honda Rune (Bloodstone Red)
  • Chaotic Reason
  • Chaotic Reason's Avatar
Re: Can ST gauges be taken apart and repaired?
06 Oct 2011 04:09
#481645
I've taken my gauges apart to change the bulb. I'd think you should be able to take them apart further for any repairs... And as for the decreased illumination, you can get high output led's that can still fit in the stock plugs. That should make it fine to see.
Michael
1980 KZ1000 shaft drive
  • Nebr_Rex
  • Nebr_Rex's Avatar
06 Oct 2011 04:51
#481648
zresto.com
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
06 Oct 2011 06:31
#481657
Nebr_Rex wrote: zresto.com
ditto...it is about US$90.00 per unit + shipping...they look like new when returned. :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • 300kph
10 Oct 2011 03:04
#482290
Got a prompt reply from Bob Harrington from Zresto and they do the entire 4 gauge cluster from the Z1R... they are coming off and going out this week!
That's the finishing touch I think I will need!
W
1978 Yamaha XS1100
