fork tube size for headlight bracket
  • STUNTMAN STEVE
  • STUNTMAN STEVE's Avatar Topic Author
03 Oct 2011 18:55
#481219
Trying to buy some headlight brackets for my 84gpz as I took the fairing off.. want to put a smaller round or square light mounted to the forks. Thanks for any help.
'84 gpz750 work in progress/ money pit
  • MFolks
  • MFolks's Avatar
Re: fork tube size for headlight bracket
03 Oct 2011 20:18
#481224
I'd think industrial split shaft clamps drilled and tapped for the lights would work. They come in SS,& Steel:
www.staffordmfg.com/Search.aspx?famName=...jRzasCFYldTAodJmd20w
www.ondrives.com/couplings-clamps-and-co...el-9-50mm-bores.html
www.climaxmetal.com/prod_2p1.htm
If you wanted a bar type light mount, a 1" square piece of Aluminum 6061 or 7075 cut to fit across the fork tubes & secured to the shaft clamps will be more than strong.
  • martin_csr
  • martin_csr's Avatar
Re: -
03 Oct 2011 21:35 - 15 Feb 2013 11:49
#481235
Last edit: 15 Feb 2013 11:49 by martin_csr.
