Hi friends
  • Z1Bama
  • Z1Bama's Avatar Topic Author
Hi friends
17 May 2006 19:07
#48114
Im installing 3 ohm ACCEL coils/8.5 mm plug wires along with dyna s's in the points box on my 1974 Z1 900. The old dyna 3 ohm coils came off and were bolted thru the holes in the bars running thru the coils. was this considered a grounded mount? The ACCELs are a little longer so the bars the dynas were bolted to are coming off and will use mounting bars that came with the new ACCEL kit. Anyway was it correct to bolt these kinda coils thru the holes on each end this way? Thanks for your comments
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
Re: Hi friends
18 May 2006 00:35
#48178
Yes that's the correct way to mount them.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
  • loudhvx
  • loudhvx's Avatar
Re: Hi friends
18 May 2006 09:14
#48234
Electrically, the core of the coil doesn't need to be grounded.
  • Z1Bama
Re: Hi friends
21 May 2006 22:04
#49018
Thanks guys.
