Lights not working all of a sudden?!
  • tbaumga2
  • tbaumga2's Avatar Topic Author
01 Oct 2011 20:33
#480838
Yesterday, I was changing out the turn signal relay on my 84 gpz 550, and noticed one of the fuses was blown, so changed that while I was at it. Turned it on, everything worked great. Today I go to run it, and none of my lights work at all. The bike still started and ran, but that's about it. I checked and changed all the fuses again, but nothing seemed to work. Any ideas? :S
  • MFolks
  • MFolks's Avatar
Re: Lights not working all of a sudden?!
01 Oct 2011 23:25
#480864
Glass tubed fuses? Replace them all as age & vibration will cause them to fail.They are the AGX size sometimes available at auto parts stores and boating supply places.
If the fuses check good, then it's time to get out the multimeter, testing for where the voltage is and isn't.
The Dreaded Shorting/Intermittent Electrical Problem!
Here is the most basic method I know(Taken from www.kzrider.com by member Patton)
1. Charge your battery and have it load tested if you can. The floating ball hydrometer can be used to check the specific gravity of the charged cells in the battery.
2. Disconnect the Black lead from the (-) Battery terminal... or Red from the (+) Battery terminal, it does not matter which one. Just 1, not both!
3. Connect one of the following test setups in series with the Battery terminal and lead:
3.1 A 12 V light bulb,
3.2 A 12 V test light,
3.3 A 12 V test buzzer or,
3.4 A 12 V horn... you get the idea.
4. With the Ignition Switch OFF, go through your harness and wiggle the wires while looking/listening for the test setup to go on/start buzzing.
5.With the Ignition Switch ON, repeat the test except this time the looking/listening for the test setup to go off/stop buzzing.
6. Be prepared to open the Ignition switch and check/test for solder joint failure and or circuit board micro breaks (don't ask how I know this ).
7. Be prepared to pull the wires out of the Head Light to test for failures at or near the grommet.
8. Be prepared to open the harness at or near the Steering Neck for failures. This is where wires tend to exhibit fatigue due to repetitive movement.
9. Be prepared to open the left and right switch gear to search for rust and or broken parts. CAUTION: watch out for flying springs, ball bearings and stuff. Do indoors on White sheet (again don't ask ).
10. Be prepared to follow the heavy gauge wire from the Starter Solenoid (Relay) to the starter for bare wire exposure. Especially near bends and grommets.
11. If you can reproduce the fault symptom your are pretty much home free. Be prepare to find and repair/replace any internal wire breaks, insulation break downs, exposed wires, rubber grommet failures, etc. Often, shrink tubing will solve the problem temporarily until something better can be done.
12. I use a very good electrical contact cleaner/preservative called De-oxit made by Caig Labs in San Diego Ca. Their website is www.deoxit.com It can be purchased at Radio Shack and any other electronic supply store. I use it on all of my motorcycle’s electrical connectors , in my home entertainment center’s stereo patch cords and cordless phones charging cradles.
  • tbaumga2
02 Oct 2011 22:31
#481064
thanks! that sounds like enough to keep me busy for now lol i'll give it a shot and report back
