removing turn signals
  • STUNTMAN STEVE
  • STUNTMAN STEVE's Avatar Topic Author
27 Sep 2011 16:13
#479990
Hoping to have my bike back from the shop in the next couple days. I want to strip all the plastic on it, and get rid of the turn signals. Can I just unhook them and cap off the wires? Or do I need to chase them all the way back to the fuse box? Something else
? Thanks for any help...
'84 gpz750 work in progress/ money pit
  • MFolks
  • MFolks's Avatar
Re: removing turn signals
27 Sep 2011 18:40
#480017
For the front turn signals, open up the headlight, trace back the three wires for each turn signal & unplug them. For the rear turn signals, trace back the two wires on each and unplug them.
Rather than cut up the harness, try to keep it intact in case you want the turn signals back on.
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
  • STUNTMAN STEVE
27 Sep 2011 23:17
#480088
Nice thanks
