79 Kz650 starter solenoid replacement
  • Onetype
  • Onetype's Avatar Topic Author
24 Sep 2011 05:03
#479114
Wiring the bike tonight and the starter relay apparently went bad. Tested it with a small relay, and got it to click. I can jump the bad relay with a screw driver and obviously it will turn over. So I need to grab a new one, What can I use as a replacement? Or what amp relay do I need to get?
  • Motor Head
  • Motor Head's Avatar
Re: 79 Kz650 starter solenoid replacement
24 Sep 2011 14:45
#479187
Well you can order the OEM type from kaw, or a replacement through, say Z1. Or Ebay has them, then you could just go to a small engine shop, and get a solenoid for a riding mower/ generator. OEM like $65, Universal, or small engine, around $30.
Won't get into dia as it sounds like you've done that. GL.
  • Onetype
24 Sep 2011 15:50
#479206
Thanks motor head. I'm on the hunt for one today. I saw one on a generator at the store, didn't see any on the shelf though. Going to try another place.
  • MFolks
  • MFolks's Avatar
24 Sep 2011 16:02
#479211
Try any of the riding lawnmower shops, for about $15-$20 you should be able to find one that will work,keep in mind you may have to add an additional grounding wire to make it work as most Kawasaki ones are ready to go without needing more wiring.
Take your old one along for size comparison/mounting configuration.
  • Onetype
24 Sep 2011 18:57 - 24 Sep 2011 18:58
#479243
Thanks guys. I found one at Sears for $14.99, hope it works, I have one on my brothers xs400 that i'm building him, but I'm not ready to rob it just yet lol.
Last edit: 24 Sep 2011 18:58 by Onetype.
