Why?
- 0Z.Z1R Mk2
Why?
19 Sep 2011 08:14
Why would my brake warning light show,when the brakes are applied,but the lights are working fine?
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
Re: Why?
19 Sep 2011 09:26
Sounds like the brake light on your indicator panel is working properly. The light that you're calling a warning light should come on everytime you apply the brakes and the brake light comes on. If that indicator light does not come on when you apply the brakes, it shows your brake light is not working. Ed
Re: Why?
19 Sep 2011 10:18
If just riding along (without any brake application) and the brake dash light is blinking, it's a warning that the rear brake light is non-functional (for whatever reason, but usually a burnt out brake filament in the bulb).
Basically informing the rider that the rear brake bulb filament isn't going to light up when the brakes are next applied.
- 0Z.Z1R Mk2
Re: Why?
20 Sep 2011 03:05650ed wrote: Sounds like the brake light on your indicator panel is working properly. The light that you're calling a warning light should come on everytime you apply the brakes and the brake light comes on. If that indicator light does not come on when you apply the brakes, it shows your brake light is not working. Ed
OK thanks...thats normal then.
Cheers guys.
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
Last edit: 15 Feb 2013 11:33 by martin_csr.
Re: Why?
20 Sep 2011 09:26martin_csr wrote: There's a test for the Outage Indicator Switch. Remove the tail light bulb, turn on the ignition switch, then apply & release the brake (Fr or Rr) - the stop lamp indicator light at the meter should flash. That's how it is on my 81 650 anyway. I guess yours is the same.
Or disconnect the under-seat wire to the brake light.
