Ideas for new gauges
- Kellen79_650
16 May 2006 13:06
I just got my first bike which happens to be a 79' KZ650B. I have experience rebuilding cars and trucks but this will be my first motorcycle project. I really like cafe styling, not for the race inspiration but for the simplicity of the look. With this in mind, I would like to do something different with the gauges. I would love to have a gauge mounted into the headlight assembly or the gas tank, but I am not sure how plausible this is. Basically I want low profile and slick looks. Anyone have any ideas?
Kellen
Post edited by: Kellen79_650, at: 2006/05/16 16:09
Kellen
"In the beginning of a change, the Patriot is a scarce man, Brave, Hated and Scorned. When his cause succeeds however, the timid join him, for then it costs NOTHING to be a Patriot."
~Mark Twain
~Mark Twain
- Maxwedge
Re: Ideas for new gauges
18 May 2006 13:22
I built a bracket to drop mine down about 4 inches and and tucked in closer to the handlebars. I also made some white faces for them with a lot of help from people on the boards. search for the "white face gauges" thread in this same forum. I can post up some pics. in a few days when I have it all back together.
- DanOz7Five0
18 May 2006 16:21
Many of us have been "flipping" our gauges lately. Basically mount the bracket that they are on to the underside of the top triple tree. Basically you remove the gauges, cut off the stud that is on the bottom, drill a hole through the bracket and use nuts and bolts (I used stainless allen head screws, washers and nylock nuts) to mount the bracket lower.
Here are some pics
Here are some pics
- Kellen79_650
19 May 2006 07:59
Maxwedge, I like the idea. When you drop them down that far is your view of them obstructed. What kind of bars do you have. I have some cafe bars on mine so I don't think there will be visibility issues.
Dan, For whatever reason I wasn't able to see your pictures, it may just be my work computer so I will check again when I get home. That sounds like a pretty simple solution. Have you run in to any problems with your setup?
Kellen
Kellen
~Mark Twain
~Mark Twain
- DanOz7Five0
19 May 2006 14:20
Kellen79_650 wrote:
The only issue I had was the speedo cable. Mine was way too long to begin with though. I went to my Kaw dealer with my too long cable and after some convincing I asked them to find me one 6" shorter. After about 10 minutes they had one for me. No clue what bike it was from but the Kaw part number I believe is 54001-1123.
You can also see the pics by clicking my blue bike below
Kellen
- Kellen79_650
31 May 2006 09:31
So I found a gauge/headlight idea online that I would like for my bike. Now the hard part is physically finding one or making one myself. I think that is one is from a british bike but I am not sure. Anyone have any ideas or experience with such a thing?
Post edited by: Kellen79_650, at: 2006/05/31 12:32
~Mark Twain
~Mark Twain
- kawtoy
31 May 2006 16:36
That is from an old Triumph Bonneville. The problem with using gauges from another bike is the speedo gear ratio. Also the Triumphs have the speedo gear on the rear wheel, at least mine does. Anything can be done though. Try to find one that is in rought shape. Get it and see if will even work. If it does then you can paint it or just find one that is like new.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
- Maxwedge
02 Jun 2006 19:03
I have Cafe bars (might switch to clip-ons soon) and I'm 6'3" so I can see the gauges fine. I'm going to have to fabricate or modify the headlight mount in order to make it all work. Thanks for the short speedo cable part#, I may need that. Haven't got that far yet. I've been busy trying to finish a boat project, so I haven't worked on the bike much, but I will try to post up some pics as soon.
- RetroRiceRocketRider
02 Jun 2006 19:16
Maxwedge wrote:
Most of the folks like DanOZ who have flipped their gauge bracket to lower the gauges have just used the stock headlight mounting brackets to lower the headlight as well.
Basically all you need to do is remove the brackets from the fork tubes, turn them upside-down, and then switch sides with them (right to left, and left to right) to lower the headlight assy.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
