Headlight!
- ed spangler
- Tennessee Z
Headlight!
17 Sep 2011 09:41
The headlight on my 1975 Z1-B is not very bright. I have checked Battery, charging system, connectors etc. etc. Bike starts and runs good, Simple question....will an aftermarket Halogen bulb fit my bike? I am hearing from lots of people this is a very common problem and that a Wagner H6024 will fit the bike and cure the problem! Thoughts?
Anyone use a different bulb with success?
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
Re: Headlight!
17 Sep 2011 09:51 - 17 Sep 2011 09:52
I've used a variety of different halogen lights over the past 34 years including an expensive Marchal H4, 100w offroad H4 bulbs, Sylvania sealed beam, etc. I found that Wagner provides excellent lighting, doesn't put an excessive load on the electrical system, is very affordable, and is robust enough to outlast the others I have tried. I even bought a spare to keep in my parts box in case Wagner ever stops making them. Below is a link so you can see pricing. Ed
www.summitracing.com/parts/WAG-H6024/
Last edit: 17 Sep 2011 09:52 by 650ed.
Last edit: 22 Jan 2013 03:39 by martin_csr.
- gengomerpyle
Re: Headlight!
17 Sep 2011 12:04
not sure about yours, but when my headlight was dim it ended up being a blown out bulb.
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- ed spangler
- Tennessee Z
Re: Headlight!
18 Sep 2011 09:06
Hello Patton,
match suggesstion gave me an idea....
Well.............or double check the wiring again to make sure the lead for the high beam isn't connected to the ground!!
:silly:
Not that that could happen?? SIGH!!
Sigh!!
Bulb is brighter now. :woohoo: ..... but may still go with a Halogen!
ED
Sigh!!
ED
- wireman
Re: Headlight!
18 Sep 2011 09:18
you can use same halogen bulb as 70s chevy trucks use
