Warning: Undefined variable $end_tag_params in /home/kzride5/public_html/libraries/kunena/External/Nbbc/src/BBCode.php on line 2321
What does this plug in to?
  • xbmxxx
  • xbmxxx's Avatar Topic Author
12 Sep 2011 22:12
#476230
I pulled my headlight to get to the wiring today while trying to diagnose a charging issue, and noticed this 9 pin connector just hanging out in there.
In my manual it says to unplug it to test the dynamo, but mine was never connected in the first place, and I cant seem to find anything that it could plug in to.
There are also a few other wires in there with no friends. When I got it it was running/charging before a nice electrical fire melted part of the harness. I pulled the whole harness off, repaired the burnt wires, and put it back on. None of these were connected before this, and it has me really confused.
I think I diagnosed my problem as a bad REC, as when I tested it per the manual, I get an open reading (infinity) across every connection.
76 KZ750B Twin
  • testarossa
  • testarossa's Avatar
Re: What does this plug in to?
12 Sep 2011 22:30
#476236
If you include the Year and model of your bike it will help those who are answering your question.
I'll take a stab. It looks like the 9 pin connector that goes to the dash on my 78 KZ1000A2. It has the wires to all the idiot lights and the back lighting for the gauges.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • xbmxxx
12 Sep 2011 22:39
#476239
Sorry! its a 76 KZ750.
I did pull the dash off as none of it worked anyway and re mounted just the IGN switch. Is anything charging related ran through that?
76 KZ750B Twin
  • testarossa
12 Sep 2011 22:48 - 12 Sep 2011 22:49
#476242
Not to my knowledge, but I'm not too familiar with the KZ750 wiring. Look in the filebase, there should be a wiring diagram for your bike in there. Click this link: kzrider.com/filebase/cat_view/85-1976/93-kawasaki-kz-750-b1 it will take you there, but you will have to click the pdf for your wiring diagram.
BTW go into your profile settings and put your bike info in your signature so it will always be there when you post questions.
2004 ZX-10R
Angola, IN
Last edit: 12 Sep 2011 22:49 by testarossa.
