WHAT ARE THESE WIRES TO?
  • badrhino
  • badrhino's Avatar Topic Author
09 Sep 2011 12:51
#475391
Here is a picture of the wires from the headlight bezel. I know the three at the bottom of the pic are to the headlight itself, but what are these other two for?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • riverroad
  • riverroad's Avatar
  • 1980 1000LTD B4
Re: WHAT ARE THESE WIRES TO?
09 Sep 2011 13:45
#475401
I think they're to your r/h turn signal.
  • MFolks
  • MFolks's Avatar
09 Sep 2011 16:11
#475438
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
The following user(s) said Thank You: Humenik
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
09 Sep 2011 16:15
#475442
Front Brake Switch...
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • badrhino
09 Sep 2011 23:33
#475538
Looks like a light blue and a brown wire.
Any other guesses?
Is Jeff the lucky winner?!
Franken Z!
  • wireman
  • wireman's Avatar
10 Sep 2011 00:19
#475555
im going with jeff B)
  • badrhino
10 Sep 2011 00:43
#475567
Ok, thanks guys!
Franken Z!
