need help with wiring up a relay
  • 94yj
  • 94yj's Avatar Topic Author
14 May 2006 13:55
#47201
does anyone have a wiring diag for how to wire up a relay ie what pins are power /load and gnd/and excite terminal i am having to build my own wiring harness and i am going to wire back to factory plus a protection relay in the main power circuit
thanks
  • jbw7300
  • jbw7300's Avatar
  • you can't ride if your fried
Re: need help with wiring up a relay
14 May 2006 14:41
#47212
most relays have the diagram on the side of it, if you post a pic of the relay i could give you an idea of what to do
84 kz 700 a1 sports
  • 94yj
14 May 2006 14:49
#47214
the ones i have seen have no diag just numbers on the side where the wires plug up
  • jbw7300
  • jbw7300's Avatar
14 May 2006 15:48
#47223
well then if you don't have a diagram you'll need to pull the cover off of the relay and see where the tangs go to, inside you'll see a energizing coil one tang to each side these would be power and ground the other two are the switched circuit. unless you have a five wire relay then i would suggest you go to the local parts store and get yourself a 4 wire relay.
84 kz 700 a1 sports
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
14 May 2006 16:32
#47235
Here's a dia. for the coil powering mod:
Post edited by: rstnick, at: 2006/05/14 19:33
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • jbw7300
  • jbw7300's Avatar
14 May 2006 16:47
#47238
there you go!
84 kz 700 a1 sports
  • 94yj
15 May 2006 06:34
#47360
thanks rstnick that is the one i needed
  • wiredgeorge
  • wiredgeorge's Avatar
16 May 2006 06:44
#47680
The person who did that drawing should have put yellow/red for the coil wires and subsequently, the "excite" wire. I always call that a trigger wire the the term "EXCITE" sounds soooooo much more... well exciting!
