kz 900
- fc5729
kz 900
20 Aug 2011 21:08
I'v got a Kawasaki 76 kz900 with dyna coils. I'm looking for the wiring diagram for the coils and the eletronic ignition.
- MFolks
Re: kz 900
20 Aug 2011 21:24
I believe your bike came with ignition points, unless the previous owner upgraded the ignition system. I suppose you could install the Kawasaki electronic ignition, but you'd need the pickup (pulsing coils),IC Igniter & related wiring along with the magnetic plates & mechanical ignition advancer.
- fc5729
Re: kz 900
20 Aug 2011 21:47
iv got all that. iv got a green a brown and a white/red.the green a bround are hooked to te coils when i hook the w/r to the green or the brown the coil works
- roy-b-boy-b
Re: kz 900
21 Aug 2011 00:20fc5729 wrote: iv got all that....
Which ignition is under the points cover, (a)points OR (b)Dyna-S OR (c)Kawasaki electronic?
