Running a bike with no battery. How to?
- Tested
17 Aug 2011 20:18
I am trying to strip my bike down as much as possible. Getting back to basics.
How do you get it back to the day when they didn't use batteries? Is it possible? What is entailed in that? What parts can be eliminated from the picture by doing so.
2008 KLR 650
1977 KZ 750
_____ Have had _____
1981 KZ 440
1970's CR 125
1982 KLX 175
1977 KZ 750
1981 KZ 440
1970's CR 125
1982 KLX 175
- zed1015
Re: Running a bike with no battery. How to?
17 Aug 2011 20:41
How basic do you want to go?
If you want just ignition for racing or daytime riding only, you will need a magneto.
Then you can remove the alt, coils ,lights, starter motor, etc.
If you still want lights then there's no point in altering what you already have as the simpler alternator replaced the more complicated and dated set-up of magneto and dynamo.
- loudhvx
18 Aug 2011 12:50 - 18 Aug 2011 13:00
77 KZ750 twin must use a battery of some sort. The type of alternator on your bike is much more efficient than the premanent magnet type, but the down side is that it needs a battery in order to work.
You can use a really small battery if you want. Some people are using little computer backup batteries. I've put a 50cc Honda Spree battery on some KZ's with your type charging system and it always worked, even when the battery was totally dead (kick-start only of course).
On the KZ twin forum there are many more threads on the subject.
www.armbell.com/kz400/index.php?sid=c35c...fcc2365&mforum=kz400
I'm not sure it's possible to swap alternators, but if you can install a 78 or later alternator, you can go without a battery. You would just use a capacitor in place of the battery. That's what I did on my 550. There are two in the photo, but I only use one of them.
In the background of the photo, you can see a 76 KZ400 with one of the Spree scooter batteries hanging down under the seat. We hadn't painted the battery holder black, yet, in that photo.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 18 Aug 2011 13:00 by loudhvx.
- loudhvx
18 Aug 2011 13:23 - 18 Aug 2011 13:26
Here's a better view of the battery (cage still un-painted).
Here's where we stuffed all of the electrics under the seat.
Here's a similar treatment on a KZ650.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 18 Aug 2011 13:26 by loudhvx.
- oldschoolbobber
18 Aug 2011 13:50
loudhvx- diggin the cafe's and your sweet setup. I think a cafe is going to be my next project.
79 KZ750 Betty the backyard bobber
- loudhvx
18 Aug 2011 14:07
Thanks! Funny, I've often thought a stripped down chopper would be a great next project.
1981 KZ550 D1 gpz.
Other links.
Other links.
- HolyKAW
18 Aug 2011 14:20
I have a 77 kz650 and have been considering weeding out unneccessary electricals too. The p/o installed electronic ignition- is it still possible to run no battery on my bike?
1977 KZ650C1
1977 KZ650B
1992 ZG1200, Kawasaki Voyager XII
Son, you just don't understand, it ain't the car I want- it's the brunette in your 'vette that turns me on!!
1977 KZ650B
- loudhvx
18 Aug 2011 15:38
Unfortunately, the 1977 KZ650 cannot go battery-less. The green one above is also a 1977, that's why he had to go with a battery.
A factory electronic ignition is more efficient for going without a battery than points, but a Dyna S ignition is not. For bikes that have permanent-magnet alternators, (like the 78 and later 650 and 750-twins), the factory electronic ignition is probably the best choice, but points will likely still work.
1981 KZ550 D1 gpz.
Other links.
Other links.
- Tested
18 Aug 2011 23:29
Thanks for all the input. I am having electrical problems with my bike and before I go putting a bunch of new electronic components in it I was curious what the essential components of the 77 KZ750 are.
@Loud - I really like the set up on on that orange bike. I will have to look into puttin a newer alt in it.
2008 KLR 650
1977 KZ 750
1981 KZ 440
1970's CR 125
1982 KLX 175
1977 KZ 750
1981 KZ 440
1970's CR 125
1982 KLX 175
- loudhvx
19 Aug 2011 14:59 - 19 Aug 2011 15:07
I'm not sure about fiting a 78 or later alternator into the 77 KZ750 twin. You can identify the older ones because they have three philips head screws in a traingle formation on the face of the cover. The later ones don't have them.
The bare bones on the 77 KZ750 would be the alternator, which consists of the field coil, the stator (both found inside the alternator cover), and the rotor (mounted to the crankshaft). Then you need a rectifier and regulator (they are separate on that bike, but there may be aftermarket units that combine them into one). You also need the points, condenser, and coil. Then you need some way to switch the bike on and off.
The rest is lighting and accessories.
EDIT: I see you found the Bare Bones thread. I completely forgot to mention it earlier, D'oh!
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 19 Aug 2011 15:07 by loudhvx.
- Pfaelzer
19 Aug 2011 15:50
check out the "SHORAI" batteries. They are really small, weigth next to nothing and can be mounted upside down etc. I have them on two of my bikes since January.
1977 KZ 1000
Queen Creek, Arizona
- Robwolf
- It's ugly, but it moves!
08 Nov 2011 18:51
How about the '79 Kz400? Is it using the same alternator as the 650. I'd love to get mine running without a battery.
'79 Kz400H1 'cafe' and '94 En500 Vulcan in swampy Florida.
