Dyna Ignition
  • supablake
  • supablake's Avatar Topic Author
Dyna Ignition
12 May 2006 21:33
#46930
I've got a 78 kz650d1. Kerker 4-1, Emgo Pods.
Any opinions on upgrading to a DYNA Ignition?
How far should I go? Dyna S, Coils, or The Dyna2000?
Aside from maintainence are there any performance advantanges over the stock ignition?
Blake
  • 77KZ650
  • 77KZ650's Avatar
Re: Dyna Ignition
12 May 2006 23:25
#46938
it should give a better spark than stock, but first, have you done the WG coil powering mod in the filebase?
07 MDP Rookie of the Year
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: Dyna Ignition
13 May 2006 09:15
#46979
Ijust recieved my dyna coils and ignition from Jeff at z1enterprises.com . I got the 2000 and the green coils. A very good price. Roy
  • roy-b-boy-b
Re: Dyna Ignition
13 May 2006 18:46
#47077
:woohoo:
Post edited by: roy-b-boy-b, at: 2006/05/14 08:48
  • MattBlack
  • MattBlack's Avatar
Re: Dyna Ignition
15 May 2006 12:21
#47433
So whats the best route to go, dyna S or the 2000? And what size coils for a k2650?
  • rammy
  • rammy's Avatar
Re: Dyna Ignition
15 May 2006 12:44
#47437
You will be more than happy with the dyna-s and the 3-ohm dyna coils(green).I did mine last year and there is no compairing it to the stock points.With the dyna-s you set it and forget about it.I makes it so much easier starting and the plugs burn alot cleaner.No high rpm miss (points bounce).B) :whistle: :laugh:
The barn yard;77 Kz650B-1 Kaw(the fun one) & 89 classic hog.
Chicago area-south burbs
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
Re: Dyna Ignition
15 May 2006 12:48
#47439
I have to say that my Dyna coil (3-ohm) was perhaps the most rewarding change I made to my bike. What a difference! Even more than the electronic ignition, since my coil was weak at best, and failing at worst....
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Dyna Ignition
16 May 2006 06:41
#47678
Upgrading the entire ignition is a real good idea. The points/condsensor thing is a matter of maintenance and expense. Old coils are old coils and really may be OK or may have problems.
As far as what type ignition, the Dyna S is less expensive and complicated. It also has less features. The Dyna 2000 has a rev limiter and allows different advance curves. On a stock bike where the rider doesn't flirt with redline much, the Dyna S seems to make sense. Where compression has been bumped a bit and the bike might be otherwise pinging down the road, the rider is usually sort of heavy handed on the throttle and both a rev limiter and being able to retard the spark a bit is a GREAT and sometimes necesary feature.
WHICH ignition is best depends on what your needs are. Since I test carburetors on my KZs, I seldom take the bikes over 8K rpm and the fleet is bone stock (only airbox/pipes mods). The Dyna S is the perfect choice for me. If I had a KZ I was using as a rider and it was perhaps hopped up a bit, I might consider the additional cost of the D2K to be well worthwhile. I HAD to have one on my last Vulcan which was pretty heavily modded and would have needed octane booster or race gas without one.
Get the Dyna plug wires/caps as well... DON'T put in a new ignition using nasty old junk or buy some NGK caps which I like better than any other I have tried. Check out the coil repowering mod in the Filebase that has been suggested as a hot spark isn't possible if you don't have full voltage running to the coils.
