Ignition switch problems
  • kfs
  • kfs's Avatar Topic Author
13 Aug 2011 18:16
#468841
I have an 81 kz1000 k1 ltd the ignition switch went bad. A new one is no longer available. Unable to find a suitable replacement (six pin + extra red/gold wire). I decided to try to fix the old one. Amazingly I think I have succeeded. The switch now tests with an ohm meter correctly for the three conections it's supposed to make (white to white/black, orange to orange/green, brown to red/gold). I put the switch back in and all that comes on when I turn switch on is the headlight. I went back to fuse box no power any more to main 30Amp fuse? there had been previously. Anyone have any ideas on tracing power from battery to fusebox? According to the wiring diagram it's only a short distance. But I can't actually see the wiring.
  • Motor Head
  • Motor Head's Avatar
Re: Ignition switch problems
14 Aug 2011 10:01
#468993
Power from the battery goes right to the 30 Amp Main fuse, so you must have a problem at the Red/ white wire, maybe where the Bullet connector plugs in. Otherwise the common problem is the clips that hold the fuse overheat, causing poor connection. This can be inside the bottom of the fuse panel. Time for another fuse panel, a lot of guy's have replaced it with a ATC type, blade fuses. That requires some rewiring instead of just a replacement.
The following user(s) said Thank You: kfs
  • MFolks
  • MFolks's Avatar
14 Aug 2011 13:27
#469032
Fuse And Fuse Holder Designations
1. The older Kawasaki’s use a glass tubed fuse with the designation of AGX 1” long. Most good auto parts stores can get them for you. They are ¼” in diameter.
2. The more common AGC is 1 ¼” long and may not fit the smaller fuse clips. Again, ¼” in diameter.
3. To clean and polish the fuse clips, I use a cotton swab(Q- Tip) and some Brasso metal cleaner or Turtle Wax Chrome Polish. I suppose any good metal polish would work.
4. These fuses can fail internally but look good, only by removing them from the clip and electrically continuity checking with either a self powered test light, or a multimeter set on OHMS can they be determined to be in good shape.
5. A physical inspection of the metal end caps for tightness will tell you if the fuse is serviceable.
6. Most modern motorcycles are now using the automobile “Blade” style fuse with the designation of ATC or ATO.
7. The reduced sized “Mini” Blade style fuse holder uses the ATM size of fuses.
8. If the fuse and fuse holder overheat, it could soften or anneal the grip of the clip, it might require squeezing the clip to restore the tightness.
9. A list of where to purchase “Blade” style fuses and holders:
www.waytekwire.com order.waytekwire.com/productdetail2/M50/...20%20%20%208%20FUSE/
www.rallylights.com www.rallylights.com/detail.aspx?ID=765
www.delcity.net/store/6!way-fuse-blocks/p_10822.a_1
10. A source for the glass tubed AGX fuses:
www.boatownerswarehouse.com/browse.cfm/2,4986.html
If possible,open up the old fuse block/panel and make note of how it's wired. Kawasaki uses buss bars to reduce the wiring congestion in these panels.
