The verdict: Dyna , HEI mod, or stock ignition
- oldschoolbobber
Thanks Guys
79 KZ750 Betty the backyard bobber
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- jramsey89
otakar wrote: Dyna is a good replacement for points. It would be the next step. As far as the progression would stand in ignition quality/technology it would be in this ascending order. 1-points, 2-Dyna, 3-OE Kawasaki electronic ignition, 4-Lou's HEI GM ignition. There are other ignitions that would be better but they are in the multiple hundreds of $.
I'm curious as to why OE is better than dyna? Not at all trying to say it that it isn't, I have OE on one of my bikes and was going to swap for the dyna off my wrecked bike when I read that OE was better somewhere on this site. (glad I decided to look it up) I have wondered what the difference was though and when I saw your post i thought maybe you could shed some light on the subject otakar.
- roy-b-boy-b
- Thank you received: 103
A bad regulator can fry a Dyna.
I have been running Dyna for 12 years. No complaints.
Dyna is a lot easier to find than stock unit.Roy
- steell
I don't know anyone that has put a Dyna S on a 750 twin, and don't know how well it would work.
Most people use the electronic ignition off the KZ440 or 82-83 KZ750 twins to convert.
I've used both with no problems.
The OP doesn't specifically ID it as a 750 twin, but the only 79 750 is a twin.
- MFolks
- Thank you received: 540
www.electrexworld.co.uk/stk-310-stator-kit-11356-0.html
- oldschoolbobber
- steell
oldschoolbobber wrote: Sorry, my bike is a 750 twin. Any thoughts on the HEI mod? Seems cheap and easy to make.
Like I can't spot a 750 twin quarter mile away :laugh:
There's two ways of using the HEI module, one is build a igniter using the stock electronic ignition advancer and pickup, the other way is to use it in a transistorized ignition with points.
Like I said in an earlier post, most people use 81 and new KZ440, or 82-83 KZ750 twin, electronic ignitions to convert the 76-80 750 twins to electronic ignition.
The HEI stuff was designed and published by our very own Loudhvx, a genius with electrons.
I have the electronic ignition advancer and pickup out of a 440 if you decide to go that way.
Here's my 79 750 twin, slightly modified
- Thank you received: 797
nice bike steel,
- oldschoolbobber
Attachment finishedproduct.JPG not found
- steell
- loudhvx
- Thank you received: 1616
There are several benefits to the Kawasaki electronic ignition over the Dyna S.
First is reliability. The Dyna S mounts it's electronics on the engine near the crankshaft. Heat and vibration are not friendly to electronics. The Kaw system mounts the electronics in a box on the frame.
Second, is efficiency. The Dyna S uses a very long, fixed dwell angle. This means at lower RPMs, the coils are getting full-current for way longer than they need to, and none of the extra current corresponds to any extra spark energy. All of the excess is just wasted as heat in the coils. As a side effect, this extra heat actually increases the coil's DC resistance slightly which actually reduces the current slightly and results in slightly less spark energy. The Kaw system varies the dwell angle using the natural effect of variable reluctors. Very clever. This means it saves power at lower RPMs and still has good dwell at higher RPMs (when the correct coils are used).
Third, the Dyna S system uses power anytime the ignition switch is on. With the factory electronic system, there is no coil current until the crankshaft is actually turning. People have cooked coils by leaving the ignition switch on, accidently, with the Dyna S.
However, as Otto said, the Dyna S is still a very good system and may even be cheaper than converting a points system to the factory electronic ignition, when all is said and done. The Dyna S can use the points coils, so if the points coils are good, there is some cost savings there. (The factory electronic system would require different coils than a points system.)
Dyna also has a very good history of replacing defective units.
The HEI module is just a replacement for the factory module in the factory system. It works basically the same, but the dwell variance is increased a little more to make it more efficient. It is also less susceptible to crosstalk between pickups that the factory system sufferes from slightly (it is noticed as little pops or puffs at idle, not really a factor to worry about).
Since you are on a twin, for which there is no offered Dyna S system, you would have to cobble one out from a 4-cylinder version. As Steell said, you can use the pickups and rotor from a 440 or later 750 twin, to make a factory system. This is what I would do. The extra efficiency is what makes it possible to ditch the battery.
The crank on a 4-cylinder bike turns the opposite way, so you can't use the advancer/rotor from a 4-cyl bike. The Pickup plate appears different too, but functions the same electrically.
The points coil will not work well for the factory electronic ignition, so you'd need one of those too. The dyna gray 2.2 ohm coil is what you'd want if you are buying new.
If you are just using the points to trigger the HEI system, then make sure the points are clean. Pitting and/or dirt introduces randomness into the dwell and timing.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
