self canceling signals?
- riverroad
- 1980 1000LTD B4
10 Aug 2011 08:32
According to my Clymers, my 1980 1000LTD is supposed to have self canceling signals?
Where's the gizmo that controls that? Think I'd kinda like to have that function.
- Motor Head
Re: self canceling signals?
10 Aug 2011 12:26
Is your Clymer right? Would be the question. They cover so many models and have more mistakes than a Factory manual. I don't have a copy for your bike but do a search on here and see, I'm pretty sure I've seen the one for your year linked for a download before.
If it had it, it would have a solenoid inside the left hand control. And a distance counter.
- KZ_Rage
- Kentucky Bourbon Barrel Ale
10 Aug 2011 13:14
Those solenoids rarely work after these many years (way too undersized to start with), you can clean & lube it and it might work but if it was like the last one I did that to it lasted for about a week then stuck again.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
- RetroRiceRocketRider
10 Aug 2011 13:31 - 10 Aug 2011 13:32
The diagram (shown below) from Kawasaki.com doesn't show an auto-cancelling module for the '79-B3/'80-B4 KZ1000 LTD's, so it's likely that your Clymer has too many KZ1000 nodels covered in that particular manual causing confusion.
Diagram:
#29 = Reserve Lighting SWitch
#9 = Outage Indicator Switch (I'm guessing for the taillight).
IIRC, Kaw didn't start using the auto-cancel signals until about '84?
Hopefully someone else that owns an '80 1000-B4 LTD and has better knowledge on this will pop in and set the story straight.
Diagram:
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
Last edit: 10 Aug 2011 13:32 by RetroRiceRocketRider.
- Motor Head
10 Aug 2011 13:35
The system was available on the 81's. Not sure about 80, but I would guess No.
- riverroad
- 1980 1000LTD B4
10 Aug 2011 13:56
Thanks for the replies ya'll. It wouldn't surprise me to learn that my Clymers has led me astray yet again. The last time, I was reading about my brakes and it said something about "performance improvement" on such and such page. Went to that page and there was no mention of brakes at all.
- les holt
10 Aug 2011 17:59
78 Z1R's had them, my 80 ltd 750 had it but my 81 ltd 750 didn't. They were nice but not many really function now so I would be skeptical of buying the components off something like e=bay to put on a bike.
Les Holt
Les Holt
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- bountyhunter
10 Aug 2011 19:05
You can buy them aftermarket. They are basically a 555 timer circuit that trns off the flasher power after a specific time interval which turns off the turn signal, even though the TS switch is still in the on position. You have to return the TS switch to off to reset it.
13 Aug 2011 21:11
I forgot to add some info.
If you find out that your bike does indeed have an auto signal cancel feature, or if you plan on installing one, odds are that around week 3 of using it you'll hate it so much that you're going to want to unplug it and maybe even toss it as far as you can throw it like I did for my ZN700. :pinch: :whistle:
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- bountyhunter
13 Aug 2011 22:55Yeah, I just got a little 12V buzzer to beep when the signals flash so I remember to turn them off. Make life simple.RetroRiceRocketRider wrote: I forgot to add some info.
