I am getting 13.29 volts while running on my 77 kz
- wdizard
08 Aug 2011 18:29
I am getting 13.29 volts while running on my 77 kz1000. Does anyone know what the ideal number of volts would be?
- MFolks
Re: I am getting 13.29 volts while running on my 77 kz
08 Aug 2011 18:34
14.5 maybe 15 tops is about all you should see. Any more and the rectifier/regulator needs checking.
www.electrosport.com
has a good troubleshooting page, take a look at it...
- bountyhunter
09 Aug 2011 16:00 - 09 Aug 2011 16:0114V nominal.wdizard wrote: I am getting 13.29 volts while running on my 77 kz1000. Does anyone know what the ideal number of volts would be?
Low voltage can be from a bad reg/rectifier assembly or generator windings.
Last edit: 09 Aug 2011 16:01 by bountyhunter.
- otakar
09 Aug 2011 18:36 - 09 Aug 2011 18:36
Why are you running on your 1000? You should be riding it.
Sorry I just couldn't resist. The book states that it should be up to as hi as 15V at higher RPM.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 09 Aug 2011 18:36 by otakar.
The following user(s) said Thank You: wdizard
- TeK9iNe
- What did you do!?!
09 Aug 2011 18:50 - 09 Aug 2011 18:51
Hmmmm... i know it should be around 14.5 Volts, and never exceed 15 Volts, but that isnt always the case.
On my CSR 1000 I have all new everything in the charging system - stator, magnets, R/R, wiring, battery, the whole job.
It still idles at your said 13.3 volts and climbs to no higher than 14.5 Volts no matter how high it revs.
13.3 Volts is a good maintenence charge, but it really isnt charging back into the battery till after it reaches 14.
Never had an issue... all brand new! Seen it before on many other bikes too...
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 09 Aug 2011 18:51 by TeK9iNe.
- bountyhunter
09 Aug 2011 20:06Check the voltage with the engine revved up, not idling. The voltage spec is for revs above about 3k. At lower revs it can drop a lot.wdizard wrote: I am getting 13.29 volts while running on my 77 kz1000. Does anyone know what the ideal number of volts would be?
