Hot ground wires then a blown fuse
  • Cobb
  • Cobb's Avatar Topic Author
08 Aug 2011 10:40
#467679
Hi Guys.
My 83 KZ750L is blowing fuses alot.
I plug in the new main 20A fuse and then some of the blk /yellow ground wires get hot, then "pop"
the fuse is blown.
  • MFolks
  • MFolks's Avatar
Re: Hot ground wires then a blown fuse
08 Aug 2011 13:51
#467713
Check your Negative(-)battery cable from the battery terminal to the engine mounting bolt. It could be loose or has failed internally due to corrosion. If the cable feels "Crunchy" when flexed, it's bad/going bad.
If the cable has failed, the other gound wires(the Black with Yellow stripe ones)will try to carry the load & overheat.
  • kaw corral
  • kaw corral's Avatar
  • Banned
  • Banned
  • Lets build one!
09 Aug 2011 12:17
#467996
Possibly the reg rect going bad
74 Z1 900
75 Z1 900
2 - 76 KZ 900
76 KZ LTD 900
77 KZ 1000
77 KZ custom 1075
78 LTD 1000
80 LTD 1000
2000 KZ Police 1015J
83 HD FLH 1340
79 FXE SG custom 1200
78 FXE SG custom 93""
