Replacing bushings/seal in 83 1100 Spectre
  • draboo
  • draboo's Avatar Topic Author
  • zzz
Re: Replacing bushings/seal in 83 1100 Spectre
12 Aug 2011 11:35
#468595
I bypassed the solenoid completely.I disconnected the cable from the starter to the solenoid and connected it to a jumper cable to the Jeep battery. Then I grounded it on top of the engine with the other cable.
The only connection that is not cleaned/checked is the ground on the engine block. I will find that today. All the others are squeaky clean.
I followed the manual as far as checking for shorts. I cleaned it with electrical cleaner and where the brushes ride with some very fine sandpaper and cleaned the little grooves out. The starter "seems" to work fine out of the bike. It did work initially after the first time I installed it along with the new fully charged battery. It spun the engine over like never before. I let it just spin without the choke for a bit to see how well it worked, maybe 10 seconds or so.Then I fired it up and went for a spin. After that 2 mile ride is when it stopped working.
1983 KZ1100D Spectre shaft
  • Motor Head
  • Motor Head's Avatar
12 Aug 2011 16:53 - 12 Aug 2011 16:53
#468637
2 mile ride, you wouldn't think that would heat up much electrically.
1 Way to check the ground, and then also the positive cable, would be to use a set of jumper cables. First attach one from the engine case to the Negative battery terminal. Then try the positive, directly to the starter post and battery positive post. Again measuring battery voltage level at the same time is good practice.
Something sounds like it has a intermittent/ loose contact.
Last edit: 12 Aug 2011 16:53 by Motor Head.
  • draboo
  • zzz
12 Aug 2011 17:16
#468646
I m damn near ready to part it out!! I am out of options, except for buying a different starter,then if it does the same thing..???
Sorry for the rant..would like to ride it to a picnic tomorrow.
I cleaned the ground connection on the engine..now every connection is clean. Tried jumping both the battery, and the starter directly again from the Jeep.I even went as far as taking the starter with the cable out, grounding the starter to the Jeep engine, and directly connecting the cable to the battery. This starter cranks just fine. I can feel the torque. The ONLY other place where there could be a bad connection,and I just thought of this while typing, would be where the starter bolts to the engine. I could shine up the starter and where it bolts, I guess. After that, I m stumped. It sure "seems" like something is locking up inside the starter clutch cover. :angry:
  • Motor Head
12 Aug 2011 18:17
#468657
Ok I know this thing is getting to you a bit. But its only a bike, it can be fixed. Crack a cold one and when you feel like going back to it then try this.
Take your volt meter and put it across the Stud that has the battery cable on it at the starter, then the other to the engine block. Then try two things, one measure Ohms/ continuity, then try Voltage as you try to start it.
  • draboo
  • zzz
12 Aug 2011 20:40
#468691
A friend(Honda car mechanic) stopped by with his meter. We tested it while under load and just over 8 volts on the meter. I took it apart, and the armature is toast. Weird,tho, that it would work just fine out of the bike..
I'm gonna pick one up somewhere. There is one on CL from a 97 KZ1000 police (same part no.) I offered him 75 and am awaiting a response. Unless there is someone on here from the Seattle area that has one..?? or just the armature, I have everything else.
Thanks M.Head for all your support.
Brad
  • Motor Head
12 Aug 2011 20:51
#468696
Well it's good news that you have it figured out, but bad to here it is shot. Got a camera to post a picture of the armature? What Toast, as it worked with no load, right? Just curious.
I think there are some members around up there in the W. maybe someone will chime in?
Posting a wanted to buy is a good idea.
  • MFolks
  • MFolks's Avatar
12 Aug 2011 22:31
#468721
Your local electrical starter rebuilding shop should have the ability to re-do your starter motor, I'd have them do this if possible first before spending money for another possible problem.
  • draboo
  • zzz
13 Aug 2011 12:10
#468794
I will dig it out of the garbage and take a few pics. It smells burnt. Some small copper shavings came out,too. I think I did something wrong on reassembly. Like I mentioned previously, it did work initially very well,then pretty much quit after that 2 mile ride.
I wonder if it would be worth it to take it to an automotive electrical place and see if the armature might be salvagable/rewound, like MFolks suggested. Hmm..
I see Z1 Enterprises has a new aftermarket one for 208.00 plus shipping. The salvage yard wants 125.00
  • MFolks
  • MFolks's Avatar
13 Aug 2011 14:38
#468809
I'd check with the rewinding shops before spending $$ on an unknown condition starter motor.
They're gonna say either yes or no about the rewinding.
  • Motor Head
14 Aug 2011 10:10
#468995
I posted some info in your "Wanted Thread"
  • draboo
  • zzz
14 Aug 2011 12:36
#469023
Thanks,MH,for the info. I had a guy call me from NY and he is sending me a starter out Monday.
I still havent dug in the garbage yet for the old armature. I would like to get the armature checked out and see if it is indeed salvageable. An extra starter is a nice thing to have handy with no kickstarter.
