intermiten miss fire
- wcrider62
06 Aug 2011 22:22
starts missing and no power bogs down on hills and then runs perfect latley seems to run fine for about 2 miles then craps out.. you can pull the plug wire hold it close and hear the spark traveling across but no difference in the motor sound, still missing. checked every thing els could it be the ignighter
1982 kz1100 spectre D1
- TeK9iNe
- What did you do!?!
Re: intermiten miss fire
06 Aug 2011 23:21
Yes, it could be the ignighter, it could also be the coils, wires, plug caps, plugs, leads from the pickups, the pickups themeseleves, advancer, and any wiring in between that makes up the ignition. :laugh:
Start at one end and good luck! - I would do plugs first...
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- bountyhunter
07 Aug 2011 05:35
When mine had an intermittent miss, it was a flaky coil crapping out when it got hot.
07 Aug 2011 10:13
An internally frayed battery+ voltage wire in the last few inches before reaching the coil primary winding can be difficult to find, and may cause intermittent coil function.
When this occurs, the external appearance of the wire (usually red or red/yellow) often looks just fine.
Diagnosis may be aided by wiggling/manipulating the suspected wire while the engine's running, or using an ohmmeter with the ignition switch OFF.
- roy-b-boy-b
07 Aug 2011 11:15
I would guess your valve clearance is too tight if this problem starts after the engine warms up. Roy
- uncledirt
07 Aug 2011 16:37bountyhunter wrote: When mine had an intermittent miss, it was a flaky coil crapping out when it got hot.
What was the matter? What did it look and what did you do? I'm getting a small issue like the other guy and I'm starting to investigate. My plugs are new though. My issue is when the bike is hot too. 1st gear only when starting out.
77 KZ650 'C'
Bachelors know more about women than married men; if they didn't they'd be married too.
07 Aug 2011 16:41 - 07 Aug 2011 16:42
The reported issue may result from something as simple as a low or weak battery, or imperfect battery cable connections.
Last edit: 07 Aug 2011 16:42 by Patton.
- bountyhunter
07 Aug 2011 16:45first gear only is not the coil. The bad coil will misfire in any gear.uncledirt wrote:bountyhunter wrote: When mine had an intermittent miss, it was a flaky coil crapping out when it got hot.
