what will make a coil pack it in?
  • Rev
  • Rev's Avatar Topic Author
06 Aug 2011 01:23
#467162
I have a 78 650b that has gone through two coils on the #2 & 3 cyl side in 1 1/2 years. Is there something that would cause a coil to pack it in, or is it just coincidental? :blink: :angry: :unsure: :blink:
78 kz650, Maxi-dwell, Modified flow through air box, Dyna coils.
Re: what will make a coil pack it in?
06 Aug 2011 02:01
#467168
Does bike have "points" ignition?
Good Fortune! :)
  • bountyhunter
  • bountyhunter's Avatar
06 Aug 2011 02:45
#467172
Running a coil with too low Ohms rating for the bike will shorten it's life severely due to heat stress.
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
06 Aug 2011 12:06
#467216
Leaving the key on will fry them. Roy
  • MFolks
  • MFolks's Avatar
06 Aug 2011 14:37
#467242
What brand of ignition coil are you using? Kawasaki? Dyna? Accel? Emgo? New or used?
  • Rev
07 Aug 2011 23:26
#467601
I have a dyna s ignition, and the 3ohm green coils. It seems to only be the left coil (cyl 2&3) that goes.
  • MFolks
  • MFolks's Avatar
07 Aug 2011 23:40
#467603
Checked the input voltage to the inition coils? When replacing the bad coil, did you ohm check the bad one? I'm wondering why it failed. How's the mounting configuration? The same for both coils? Did you use a good crimper for the ring terminals on the green coils? If the ring terminal mounting hardware screws are too long, the screws will bottom out before being tight, possibly causing surges in the primary windings.
Read this for the correct crimpers to use:
www.pbase.com/mainecruising/wire_termination
(The Good, Bad, & Ugly Wire Crimpers)
07 Aug 2011 23:55
#467612
Would also assure the terminal screw head isn't shorting out against the coil mounting spacer.
Good Fortune! :)
  • Rev
08 Aug 2011 00:18
#467620
yes I did check and the primary was 4.8 ohms and the secondary did not register at all. Got about 8 months service out of it before it packed it in. The right coil primaries are the same and I forgot what the secondaries where. All the connections were tight not touching anything to short them out. Haven't checked the voltage going to the coil though.
  • Rev
08 Aug 2011 00:22
#467621
That was an informative link Mfolks. I used a cheap crimper to attach the connector, but they seem tight though.
08 Aug 2011 00:24
#467622
Could check charging system to assure the battery isn't being over-charged.
Voltage measured across battery terminal posts isn't supposed to exceed 15 volts at 4,000+ rpm.
If charging voltage exceeds 15 volts, may require a new regulator.
Good Fortune! :)
  • MFolks
  • MFolks's Avatar
08 Aug 2011 01:12
#467632
For quality electrical crimps in a production facility, they only use the ratcheting type crimpers seen toward the last few pages of the article. When I worked at General Dynamics/Convair on the missile programs, the crimpers were calibrated for 30 days, after that time,they were checked with special tools and conducted a pull test to see what level of effort was needed to pull whatever gauge wire was needed out of the terminals.
