Head light bulb popped off. ?Normal?
  • Tested
  • Tested's Avatar Topic Author
04 Aug 2011 23:10 - 04 Aug 2011 23:11
#466905
So I was trying to figure out why my headlight stopped working and this is what I found.
The little thingy on the left is the bulb. It's rattling around inside there.
Obviously I want to have a headlight so I don't get ranned over and can sees at night.
Why would this happen? Looks like a short or to much power to the light.
ETA: I'm holding the light upside down so ya'll can see.
2008 KLR 650
1977 KZ 750
_____ Have had _____
1981 KZ 440
1970's CR 125
1982 KLX 175
Last edit: 04 Aug 2011 23:11 by Tested.
  • Motor Head
  • Motor Head's Avatar
Re: Head light bulb popped off. ?Normal?
05 Aug 2011 00:42
#466951
Doesn't look like a normal failure to me. Either sever vibration, like washboard gravel road, or possibly a over voltage. If you have a volt meter, check the voltage across your battery with about 4000 RPM. Also check headlight mounting, as it should be Isolated with rubber grommets where bolted to forks.
  • MFolks
  • MFolks's Avatar
05 Aug 2011 00:45
#466955
Is that a sealed beam headlight? Not a H4 with the removable bulb? If it's a sealed beam,it might cost $$ to replace. Model of bike?
  • Tested
05 Aug 2011 00:53
#466957
I'm leaning towards voltage.
It's a sealed beam.
2008 KLR 650
1977 KZ 750
1981 KZ 440
1970's CR 125
1982 KLX 175
  • MFolks
  • MFolks's Avatar
05 Aug 2011 01:04
#466960
Probably vibration sheared the mounting pins on the bulb causing it to float around inside. Here's a good website for replacement sealed beam headlights: www.hvccycle.com/lighting.html
If it were me, I'd be looking for a H4 conversion kit for the bike.
  • martin_csr
  • martin_csr's Avatar
Re: .
05 Aug 2011 08:23 - 22 Jan 2013 03:25
#466984
Last edit: 22 Jan 2013 03:25 by martin_csr.
