Wiring in Headlight Bezel?
  • badrhino
  • badrhino's Avatar Topic Author
03 Aug 2011 17:48 - 03 Aug 2011 17:54
#466628
Wiring inside headlight is ok I think. Except for the connectors they used back then are really weird.
How did the inside of my Headlight bezel get so rusty? The outside is nice and shiny with no rust.:whistle:
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Last edit: 03 Aug 2011 17:54 by badrhino.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Wiring in Headlight Bezel?
03 Aug 2011 17:59
#466633
Yeah , mine was like that too. The condensation just gets trapped in there and eats away at things. Doeant get blast dried like the outside :laugh:
Just give it a few quick spray coats of rustoliem or your fav ant-rust paint - and be done with her.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • Motor Head
  • Motor Head's Avatar
03 Aug 2011 18:12
#466637
Check your diagram, but the Black/ yellow is ground, and the others are most likely for accessories. See if they are hot at Key-on or key-off.
03 Aug 2011 18:52
#466648
You may want to dissolve that rust before painting. This stuff works, put it on and keep it wet for a couple hours, then the rust comes off easily. Any decent gun shop should carry it:
www.cabelas.com/solvents-lubes-bluing-bi...rust-remover-2.shtml
  • martin_csr
  • martin_csr's Avatar
Re: .
04 Aug 2011 09:36 - 22 Jan 2013 05:04
#466772
Last edit: 22 Jan 2013 05:04 by martin_csr.
  • riverroad
  • riverroad's Avatar
  • 1980 1000LTD B4
04 Aug 2011 11:31
#466788
If you use one of the many rust eating acids like the one 650ED discribes, make damned sure you don't let any get on the outside of your bucket or it will eat the chrome off of it.
04 Aug 2011 11:49 - 04 Aug 2011 11:50
#466792
riverroad wrote: If you use one of the many rust eating acids like the one 650ED discribes, make damned sure you don't let any get on the outside of your bucket or it will eat the chrome off of it.
Probably good advice; it pays to be cautious. When I used the Birchwood Casey stuff on the inside on my old fender and headlight ears it did not hurt the chrome in there at all, but I didn't put it on the outer shiny surfaces so I cannot say for sure that it won't dull shiny chrome. I cannot vouch for other, possibly more harsh, chemical treatments. Ed
Last edit: 04 Aug 2011 11:50 by 650ed.
