Charging voltage levels
  • pg4827
  • pg4827's Avatar Topic Author
11 May 2006 10:45
#46609
What should the voltage at the battery be at idle? I have 12.8 VDC is this enough to charge battery and run all the lights?
Post edited by: pg4827, at: 2006/05/11 13:51
  • gmokage
  • gmokage's Avatar
Re: Charging voltage levels
11 May 2006 12:11
#46630
For the kz440 (81) it says that it should read 14V/DC at idle.
I don't know if that level would be higher for the 1000 or not.But I don't think that it would be by much, if it is.
