What is the "other" wire on the ignition switch?
- ravenz07
30 Jul 2011 03:43
Aside from the connecter coming off the ignition, there is a wire with a tube like thing, is this just a connector, fuse, or?
(80 KZ750 LTD 4 cylinder)
1994 Kawasaki KZ1000 Police
1980 Kawasaki KZ750 LTD
1981 Yamaha XJ650H Maxim
- Qdude
- It is all good.
Re: What is the "other" wire on the ignition switch?
30 Jul 2011 05:57 - 30 Jul 2011 06:03
That is an accesory power wire. That tube thing is a connector cover.
It takes battery power from the white wire at the ignition switch and feeds 12 volts to your lamps and horn and brake light switches and regulator etc... It is powerless when the key is off.
Wiring diagram link
Go about one third of the way down and hit the "Z750E1 Wiring Diagram" (it shold be the same as the LTD) and see what that brown wire supplies.
Wiring diagram link
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
Last edit: 30 Jul 2011 06:03 by Qdude.
